This thread is about: AfterMarket Xenon/HID Kits?, it's in Lights at the Honda Civic forum Civinfo; Well i'll still be fitting mine to the 205, its a roadside swap/plug and play back to Halogens if needs be...
Old 6th February 2007, 16:26   #41 (permalink)
Dream Weaver's Avatar
Dream Weaver is offline   Reply With Quote
Old 6th February 2007, 16:33   #42 (permalink)
You obviously fancy being prosecuted...
Old 6th February 2007, 19:55   #43 (permalink)
Not at all, but of all the people I know with aftermarket HID kits fitted, none of them have had problems with the law or at MOT time.
Plus its a weekend car that does 1k miles a year, mostly at day time so they wont be used much, just fitting them cos they were free
Old 6th February 2007, 23:58   #44 (permalink)
it's one of those 'take your chances' choices...
On the plus side: (in no order!)
better visibility
cool looks
On the down side: (also in no order)
good chance they are illegal. Which means that if you crash at night, good chance your insurance will be void.
it's as good an excuse as a bored copper will need to pull you over.
potential to blind drivers coming in opposite direction as no washers fitted. see point 1.
Old 7th February 2007, 10:14   #45 (permalink)
Good point on the insurance, will have to check with them before fitting.
Old 8th February 2007, 20:52   #46 (permalink)
Bungle's Avatar
There is a good article in this issie of ADI NEWS, regardign the alarming trend of illegally fitted HID bulbs in headlamp units not designed for it.
The bottom line is that it is illegel to retro-fit the lamps. As the housing/reflector is not designed for that kind of lamp, it scatters the beam so it no longer falls within the guidlines.
Then there's the whole problem of no washers, and no leveling system.
Worryingly, a whole goup of suppliers were questioned by as if from a potential buyer, and all of the advice given was just plain wrong and illegal.
The moral of the story? Don't try it, it will fail an MOT and is dangerous.
If anybody is interested in reading it, I will scan it and post it up here.
Old 8th February 2007, 21:14   #47 (permalink)
Vivid Blue Rocks!!!
Foggy69's Avatar
ADI???
When I bought my HID kit, I had to sign a disclaimer saying they were for off road use only, so at least one company is being honest.
As to fitting HID to see better in the dark, buy some Philips 50% brighter bulbs. A lot cheaper, and make a surprising amount of difference.
Old 8th February 2007, 22:32   #48 (permalink)
I'm glad most people are agreeing with me on this. Really is dangerous.
Old 8th February 2007, 23:04   #49 (permalink)
The thing is they don't fail the MOT, so something is wrong somewhere?
Old 8th February 2007, 23:17   #50 (permalink)
They will fail an MOT.
Old 8th February 2007, 23:23   #51 (permalink)
But they don't
I have 4 or 5 friends dotted around the UK with HIDs fitted to various older cars, Pugs, Rovers etc. In some cases they've had them fitted for 4 years or more and none of them have ever failed the MOT on them.
Old 9th February 2007, 00:20   #52 (permalink)
My concern is that they blind other motorists and could potentially cause an accident. If thats not off-putting enough I don't know what is!
Old 9th February 2007, 00:39   #53 (permalink)
I'm guessing that the point is that they should fail the MOT, as being not legal.
(that's should as in fact, not opinion )
But, at the end of the day, how many times have we seen Auto Express et al run 'shock' exposures of cars that should be scrapped getting an MOT pass.
For me, as I mentioned above, I'd be less concerned about failing an MOT, and rather more concerned with being involved in a crash at night.
Note thats 'involved in' not 'causing'...
Say you are happily driving down the road, perfectly legally (except HIDs ), at night.
Car in opposite direction, driver is arguing with his girlfriend, looses concentration, and drives into you.
Air bags pop all over the place in the Civic, both cars a write off, you are ok, but other driver is in a knackered old Ford and ends up paralysed from the waist down.
Police arrive on scene.
Sharp eyed copper notices your HIDs.
Which go into the police report.
Which is given to each insurance company.
Which the other driver gets hold of.
Or his girlfriend overhears the copper / notices your HIDs / whatever.
His story of events now reads:
I was driving along, when I was suddenly blinded by the car coming in the opposite direction.
I attempted to stop, but as I could not see anything, I must have swerved into his path.
Do you really believe that at this stage your insurance co is going to fight tooth and nail for you in the hope that they win the case? When the chances are that you will loose, and they will have a huge payout?
Or are they going to drop you like a lead ballon and walk away with zero costs - and you with no insurance?
Now.
At this point, your £200 HID conversion has cost you:
£200 for the kit
£16,000 for a written off Civic
£20,000 (?) per year for life for the other driver
£gawd knows how much fine for driving with no insurance
£gawd knows how much fine for driving without due care - or worse, dangerous driving.
Would I fit them?
Old 9th February 2007, 00:40   #54 (permalink)
Can you tell how many times I re-wrote that last post?
CP's wasn't there when I started to reply!
Old 9th February 2007, 00:51   #55 (permalink)
Thats a pretty good example of my thinking TT, just fleshed out a little and made more understandable! Thanks! Being able to dodge an MOT or skip a fine really isn't the issue, It doesn't matter how many people you know that have them fitted, lots of people deal drugs and its still illegal.
There's nothing more annoying than being blinded by oncoming vehicles on back roads, you flash them to remind them to dip their beams only to realise later (and after redfocusing your eyes!) that they were dipped the whole time and just incorrectly and illegally fitted.
Sorry to rant on everyone and not having a go at you weaver, but poorly adjusted lights and fog lights frustrate me like nothing else!
Old 9th February 2007, 09:00   #56 (permalink)
That is the big worry, and i'm glad that the insurance think has been mentioned, as its the main thing stopping me fitting them now.
The MOT rules should be changed if the kits are illegal.
The main problem is the cheap kits that are out there. My kit was £300, although I got it FOC from a customer.
The bulbs in mine are completely shielded with a metal shield, and have a solenoid that operates between hi and lo beam - the beam pattern is an exact copy of the std H4 beam pattern, with no dispersal or dazzling. They also operate at 20w LESS than halogen bulbs, so the part about running hot bulbs within std headlights is wrong, as they don't actually get as hot as a halogen.
So the kit I have doesnt dazzle anyone, doesnt disperse the beam pattern, operates at less wattage than std halogens. The advantage is it gets rid of the dreadful "yellowness" of the std 205 lights, and provides a brighter, whiter light.
Maybe the MOT laws should be changed to offer HID testing, of someone could offer an approved HID test for retro fit kits? I would happily pay £25-50 to have the kit tested when fitted and receive a certificate for insurance etc
I smell a business opportunity there
Old 9th February 2007, 11:19   #57 (permalink)
Vivid Blue Rocks!!!
Foggy69's Avatar
Wow TT, great post. It made me really think about the issue.
As I have already said, I did have a HID kit fitted to my previous car, but it had the projector type (I think this is the proper name) headlamp which focus's the light very clearly. With the kit fitted, I don't remember being flashed once.
DW, I think the problem with the older reflector style of headlamp is not that the light from the bulb is directly dazzling oncoming cars, but it is the intensity of the light as it is reflected on the back of the headlight unit. The HID fills the reflector with a very bright light in a way that halogen bulbs can't
As for the general use of HID, even cars fitted with them from the factory, that comply with all the regulations and have self levelling and washers, STILL blind you. Should they be banned altogether
Old 9th February 2007, 12:09   #58 (permalink)
I'll do some more digging before fitting mine.
In general I like HID lights, and have never been dazzled by them. They do that colour change thing when coming towards you, but i've never had to squint at them, no more than std headlights.
Old 9th February 2007, 16:19   #59 (permalink)
Don't get me wrong - I love HID lights - they were a significant reason for me going for the EX
And I'm sure that there are companies out there who's products are non-dazzling (until you get 3 ton of stuff in your boot, and the non-existent self leveling system means they are focusing upwards not downwards).
But for me, until Dream Weaver gets his business off the ground ( ), the risk outweighs the benefit of a retro fit
Old 12th February 2007, 00:14   #60 (permalink)
Diesel Demon
damianscott71's Avatar
Interestingly (or not as the case may be), Autoexpress had a video report on their website regarding retro fitted HID/Xenon headlights. The upshot being the they could well become illegal and will most probably fail MOT tests in the UK.
Apparently, the reflector behind the lamp is shaped differently for HID, than standard headlight bulbs. And by fitting an HID into a reflector designed for your common or garden headlight bulb, the headlight pattern suffers from "leakage" which can dazzle oncoming motorists, etc.
I can't find the link to the footage now, if I find it, I'll add it to my post.
Or, you can try to find it at www.autoexpress.co.uk
LinkBack to this Thread: http://www.civinfo.com/forum/lights/3041-aftermarket-xenon-high-intensity-discharge-kits.html
???? xenon. - IbizaClub Forum This thread Refback 27th August 2008 23:59
Similar Threads for: AfterMarket Xenon/HID Kits?
Exhaust Trim Kits Biker1 General commercial posts 17 27th June 2008 17:53
HID HID/Xenon kits for FN2 CTR fz158 Lights 1
