| This thread is about: AfterMarket Xenon/HID Kits?, it's in Lights at the Honda Civic forum Civinfo; Hello Just wondering what's the best kit to buy? I've got my mind on the Mtec H7Fitting HID Kit, I think its 8000K anyways, any ... | ||
Hello
Just wondering what's the best kit to buy? I've got my mind on the Mtec H7Fitting HID Kit, I think its 8000K anyways, any recomendations? I guess its easy as pie to fit on a civic, as there's nothing in the engine bay Lol. Dan |
From the DFT (Dept. for transport)...
It is not acceptable to convert a head lamp unit approved for use with a halogen filament bulb to use a Xenon (HID) gas discharge bulb. The only acceptable way of converting is to replace the headlight unit with one approved for gas discharge bulbs. Such headlights will be approved to UNECE regulation 98 and 'E' marked. If headlamps approved to UNECE regulation 98 are retro-fitted they must be self levelling (as part of the headlamp system, or via self-levelling suspension), and headlamp washers must be installed. Under the Road Traffic Order 1998, it is an offence to fit or use parts which are not legal (construction and use act). Basically unless the headlamp unit is fully converted its illegal, will fail and MOT and leave you liable for prosecution. Seems like a very expensive conversion, probably not worth it. Fitting HID bulbs into a headlamp unit intended for halogen bulbs is illegal. Last edited by czechplastik; 7th January 2007 at 19:11. |
Coming from Xenon lights in my last car, I'm quite disappointed with the standard lights in the Civic. I'm going to try out the Halfords Super Brilliance lights, as reviewed by Autoexpress. Some links:
Bulb test: H4 plus 50 percent Bulb test: H4 blue Surely worth a try before splashing out on a HID kit of questionable legality. |
Vivid Blue Rocks!!!
I took a H7 HID kit off my old car, so that I could fit it to my Civic.
When I got the Civic, I looked at the design of the headlight and noticed that the bulb is not shielded at all from the front view. Probably not a good idea to fit a bright burning HID bulb to these units. When I looked at the EX model, which is fitted with HID lamps, the internal design of the headlamp is different, it shields the bulb from view. If you do want to fit a HID lights, and it did make a difference to my old car, then it might be an idea to fit the headlight units off an EX. It might prevent been flashed all the time by oncoming traffic because you are blinding them. I agree with Dawson, the lights on the Civic are poor. I am waiting for a dry day to be able to fit some Philips Vision Plus bulbs. Hope that improves things. |
#10 (permalink) | |
LEGALITY NOTES ON ROAD LEGALITY AND QUALITY OF OUR HID :
Hey yal
I just got back from collecting my new car, it went in today to get a HID conversion kit fitted, and OMG the out come is the shexx!!! Its H7 fitting, and 6000K brightness, I am stunned on the result, this is the reason why I started the whole topic regarding on fitting some on the civic. Il get some pics later for you all Dan |
technically they are illegal, but police rarely stop u, because u drive a new car. if it was on an old car, police mite bother to stop u, but if new, they may not tell the difference between standard OEM HID and conversion kits (even though its evident they are much brighter). i personally wouldn't worry about it. with regards to the MOT issue, just take them off! people do that with catalytic converters so why cant u do it with HID kits. foggy69 made a good point bout them being on the civic though.
#14 (permalink) | |
Pictures would be great, especially of ones at night showing how bright the light is from the inside of the car. |
#15 (permalink) | |
#16 (permalink) |
Here you go Playa
This is the MTEC HID 6000K Kit, cost around £230 Fitting cost about £90(N), then they took it through MOT to check the lightning is in the right position etc... and It passed, so I guesed it is legal? ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#18 (permalink) |
5 seats are a must!
There's is an aritcle about these kits in Auto Express last week (or the week before?), can't find the article to hand.
Basically they are not legal as whether the lamps are Approved or not is not the issue, it's down to the installation. The HID bulb does not produce light in the same way as a normal bulb and as such gives incorrect lighting when installed in a lamp designed for normal bulbs. This alone will cause an MOT failure, cause you to dazzle other road users and be liable for a fine and points. DOT marking (if actually attained) is normally applied for US product. For EU I'd expect to see an 'E' and 'e' mark, none of which seems available. The light produced whilst bright is a lot worse than a standard bulb, so if you want worse lighting at night, a few points on your license and a few pounds lighter for the fine and the kit carry on. (Not for road use springs to mind |
#20 (permalink) |
5 seats are a must!
I know but some don't listen, I'd love to have an array of KC's to dazzle any oncoming cars with such conversions (not legal either and rather childish
Just to prove the point the pics from Danko are quite dazzling. |
| Exhaust Trim Kits | Biker1 | John Pease Honda | 17 | 27th June 2008 17:53 |
| HID HID/Xenon kits for FN2 CTR | fz158 | Lights | 1 | 20th October 2007 23:08 |
| Body kits | civc_89 | Any non Civic chat here please! | 2 | 16th October 2007 00:56 |
| Aftermarket body kits | WeeAndy | Wiki Article Discussion | 0 | 26th August 2007 17:56 |
| Body kits for civic? | pikkumies | Cleaning and Styling | 13 | 17th January 2007 16:37 |
