This thread is about: [Interior] Blue Interior Lighting, it's in Lights at the Honda Civic forum Civinfo; Had a think about this and I am going to istall some blue LEDs that come on with ignition. Already run an ignition switched power ...
Old 6th August 2006, 16:02   #161 (permalink)
Tomthumb's Avatar
Had a think about this and I am going to istall some blue LEDs that come on with ignition. Already run an ignition switched power supply to the fuse area will use that.
When you get in car the blue interior light comes on then when you turn the key that will fade and the footwell lights will come on. Should be a good effect dont think I will try and build a fade into the foot lights might be beyond me, but then again a capacitor and a couple of resistors???
Will do a how to when I do this.
Tomthumb is offline   Reply With Quote
Old 8th August 2006, 12:11   #162 (permalink)
DanKo's Avatar
Bought some blue bulbs yesterday, 1.99 for 2 for the front, and 1.99 for the middle, how ever as they are sorta painted they end up abit turquoise/green, and after reading this post, Just placed an order for the LED, festoon middle light, and the front 4LED lights
Il get some pic's when its all done, Anyone know where I can get like a 12"+ NEON light tube, so I can stick it in the boot to light up the sound system:P
Regards Dan
DanKo is offline   Reply With Quote
Old 15th August 2006, 14:32   #163 (permalink)
Charles_Harding's Avatar
Interior LED's
Have done both front & middle with the LED's.
Very pleased with the result and you can still read maps in the front - not that they are needed with the Sat Nav!
Tip : LED's are polarity dependant. If you fit them and they don't work, either turn the car round 180 or turn the LED's 180!
Old 17th August 2006, 22:27   #164 (permalink)
Tomthumb's Avatar
I have some nice led clusters ready to fit, just need to find some time now
Old 18th August 2006, 17:47   #165 (permalink)
Malk's Avatar
Originally Posted by Tomthumb
The fuse box connector, the top right is a 12v with car side/head lights. Looking at the previous photos that signal goes to whatever the green plug is in. The bottom left I dont know couldnt get anything from it.
Tomthum,
could the bottom left be a door open signal?
i was thinking it through and if the footwell lights come on when the door is opened and fade down to a glow when it is closed then one of the pins must be a door open/closed pin??
Also what do all the other pins do?
so far as i can tell you only mentioned the top right and bottom left ones?
Malk is offline   Reply With Quote
Old 19th August 2006, 05:56   #166 (permalink)
Tomthumb's Avatar
I couldnt pick up anything on that bottom left one but it must be something like that. That connector is ude for several addons, dont know what it seems to be a general plug the extras in socket
Old 13th September 2006, 07:46   #167 (permalink)
Velocity's Avatar
Hi all,
Can anyone who has had the ambient blue footwell lights fitted please tell me if the lighting is only in the drivers footwell or in both the drivers and passenger side. In the brochure it looks as though it is in both driver and passenger side.
The salesman I talked to over the phone about having this fitted informed me that it is only on the drivers side. Is this correct.
Velocity
Old 13th September 2006, 07:54   #168 (permalink)
basegreen's Avatar
Both footwells, definitely.
Old 13th September 2006, 08:06   #169 (permalink)
Velocity's Avatar
Thanks basegreen, I will get onto the dealership and speak to this salesman again and inform him that the lighting is on both sides.
Velocity
Old 29th September 2006, 17:32   #170 (permalink)
HURMUND's Avatar
Just fitted blue LED's front and rear on our EX..........looks well cool (not chavish I hasten to add). Compliments the blue footwell lighting well.
HURMUND is offline   Reply With Quote
Old 8th October 2006, 10:06   #171 (permalink)
Red face
Gone really mad!!
Gone and bunged 20 sperate blue LED's in the ceiling of my bathroom.
I can just sit there and imagine I'm behind the wheel all the time now!!!
Maybe I'm just losing it!!!
Old 8th October 2006, 10:14   #172 (permalink)
allan40alt's Avatar
Charles, have you coated the mirrors and shower cubicle with 'Rain-x' as well?
Old 8th October 2006, 10:24   #173 (permalink)
No I've got a wiper fitted!!!
Old 8th October 2006, 11:55   #174 (permalink)
Bassa's Avatar
Could the PC monitor's back of the screen surface cleaner work on the windscreen's interior?
Allan was having some trouble titivating, accessing & cleaning the lower part.
Bassa is offline   Reply With Quote
Old 8th October 2006, 12:49   #175 (permalink)
allan40alt's Avatar
Not the angle the screen is....but it would work a treat in the shower cubicle!
Old 8th October 2006, 13:05   #176 (permalink)
Bassa's Avatar
The bottom of windscreen's interior is very awkward to reach and certainly not at all knuckle friendly - what we need is a thin (like the normal cloths) microfibre mitten - ambidextrous of course.
When's the next 'Dragons' Den 'series?
Old 8th October 2006, 17:21   #177 (permalink)
Oi!
This bits about blue lights
Cleaning is down a bit
Old 8th October 2006, 17:47   #178 (permalink)
Bassa's Avatar
Sorry Charles, obviously need to clean my screen. Will go and titivate.
Old 8th October 2006, 19:00   #179 (permalink)
lennie.c's Avatar
blue lamp
in the thread for the blue festoon you stated 269 but autobulbs show it as 264 so who is right
cheers
lennie.c is offline   Reply With Quote
Old 8th October 2006, 19:46   #180 (permalink)
allan40alt's Avatar
cheers
I ordered the 269 (it's a 6 LED 30mm festoon) in Blue or bluish white which I'm hoping will go with the 501 LED Super Bright White I've ordered.
Ps: The 264 is a 42mm.
Search this Thread:
Advanced Search
Similar Threads for: [Interior] Blue Interior Lighting
Install Ambient Blue Lighting (Switched on by Main Lights) tamar How To 31 27th February 2008 10:51
Blue Lighting CE_CIV_sport07 Lights 2 7th October 2007 19:10
Blue Ambient footwell lighting Primuldak Wiki Article Discussion 0 5th September 2007 18:42
Auto dim ambient blue lighting crispy Lights 75 5th June 2007 22:25
can any one post some pics of the oem blue lighting? gray52 Lights 0 5th December 2006 23:02
