This thread is about: Xenon HID - parking light bulbs don't match, it's in Lights at the Honda Civic forum Civinfo; Originally Posted by allan40alt ...see my picture above #5. You won't get a better match, in my opinion. Ps: Shipping is free to Europe by ...
Old 26th February 2008, 15:54   #21 (permalink)
Ps: Shipping is free to Europe by the looks of it Free Shipping :: Autobulbs Direct Ltd - Xenon bulbs, car bulbs, wiper blades, headlight, Osram, Ring, Philips . Unless it is under £10 or over £100 .
Yes that`s right....
But I can`t make the order,It says: the card is declined by the bank
And I dont have any other card....F.....k!!!
Damir Cvtec is offline   Reply With Quote
Old 26th February 2008, 17:26   #22 (permalink)
Bit confused here. The normal civic driving lights (don't know the English word..) are Xenon here in Belgian type R's. The parking lights and the lights you can use under low visibility when not bothering other drivers are not. Is it simply the case of replacing the none xenon bulbs with Xenons?
Old 26th February 2008, 17:38   #23 (permalink)
allan40alt's Avatar
They will accept PayPal, Cheque or Postal Order. It will delay it by a few days but at least you'll get them.
Why not send them an email and explain the problem, they're very helpful.
Good luck.
PS: Or just get a friend to order them on their card and give them the cash.
Old 27th February 2008, 07:28   #24 (permalink)
It wasn’t me!
NO!!
The Main beam is a conventional Halogen bulb (H1) and can be replaced with a Blue vision type bulb to make it look less yellow next to the Xenon dipped bulb.
I hope that clears up the confusion
Old 27th February 2008, 07:41   #25 (permalink)
NO!!
Yes thank you, I am a bit disappointed with not having, what I think is called, the high beam and parkinglights in Xenon. I replaced the bulbs in my 1.7ctdi civic with Xenon look-a-likes from Philips and Osram. They both didn't last long(Osram wins by a month). Replaced them 3 times in the year I had this car.
May I bother you to explain why this isn't possible. I believed Xenon consisted of a ballast (converter that supplies the 12 000 volt or more starting voltage) and of course the head unit and the bulb. I hoped a little extra wirering and a bulb would do the trick. I think I read somewhere the Xenon gas in in de HID itself and not in the bulb. In that case it would probably not be possible without a new HID.
Old 27th February 2008, 08:24   #26 (permalink)
Good luck.
If they are helpfull.Ill do that.....
Lol,another problem,paypal won`t accept my card either....
I can order records from UK , but on some sites it won`t accept the card!
Yes I`ll figure something out....****!!!
Old 27th February 2008, 11:24   #27 (permalink)
It wasn’t me!
Its because the bulb needs time to charge up before it gets to maximum power.
Thats why it can't be used as a main beam
Old 3rd August 2008, 03:53   #28 (permalink)
AU_CTR's Avatar
I like others disliked the standard lights on the Type R so I decided to change over to HID
First I changed what others refer to as dipped on this forum I labeled my photos as (Main) I also changed the parkers, I was so impressed with the light output and disliked the colour mismatch with Main (High Beam) I decided to change them over as well
Mine came with 18 months warranty on the ballast and 12 months on lamps
PS High beams come up to full brightness in about 2 sec first time then instantaneous following times
Attached led parkers picture
Here are the other pictures
http://photos.newsys.com.au/gallery/5527262_4gcgW
AU_CTR is offline   Reply With Quote
Similar Threads for: Xenon HID - parking light bulbs don't match
[HOW TO] Replace headlight bulbs & front position light jw How To 56 6th October 2008 19:12
Paint Colour Match Problems THE DUTCHMAN Bugs, faults and irritations 13 29th October 2007 21:23
HID Side light/HID colour match DigitalPlumber Lights 16 16th October 2007 13:11
Fog Fog Light Bulbs scol78 Lights 0 23rd March 2007 12:35
Match the colour of your Civic Gweneira Any non Civic chat here please! 222 25th October 2006 22:32
