Bulbs Headlight update with LED or HID - Civinfo
 4Likes
post #1 of 29 (permalink) Old 13th December 2016, 14:09 Thread Starter
Lightbulb Headlight update with LED or HID
So, going angry of changing high power halogens every several months, I am thinking about some updates, what you think guys? - maybe some one know some good LED's, without any problems, heat , and good cut off, or maybe HID will be way to go, share you experience.
xfiniti64 is offline
post #2 of 29 (permalink) Old 14th December 2016, 14:25
I have cob Leds in my car and they are amazing, super bright and unlike hids they don't need to heat up for colour so you can use them as your full beams also.
razz is offline
post #3 of 29 (permalink) Old 14th December 2016, 19:44
Dutch
Xa4cornelis's Avatar
Car: 2015 Sport 1.6 sporty blue
I have had both, I like my leds very much now, direct full light no startup time, nice beam
Verzonden vanaf mijn iPhone met Tapatalk
RA108 and Farqui like this.
Xa4cornelis is offline
post #4 of 29 (permalink) Old 15th December 2016, 06:59 Thread Starter
Which type of LED ? i did digging. There are several Chinese companies which produces more normal LED's, CN360LED - LED auto lamp suppliers around the world.LED headlight,High power light,SMD car light 360 INTERNATIONAL GROUP LTD as you see it has many generations.
The most popular are 7gen.
regardless of the language, he shows how it works in reflector. And it's not good.....
The best LED I've found is BT-AUTO Lighting the problem is that they are wholesalers, min order is 10 sets and there is no resellers, retailers
they are ideal replacement of hologen. Whay is so , X-tremeVision LED Fog Lamp 78719719 | Philips thay perfectly copied philips design, and its working.
There are very few tests on youtube
https://bt-auto.en.alibaba.com/produ...light_Kit.html
post #5 of 29 (permalink) Old 18th December 2016, 10:04
Lithium Flower
Grayfox's Avatar
Car: '11 Impreza R Special
Eco display Eco display
@Mr_JP sells some Philips LEDs.
He can give you a price on postage.
Grayfox is online now
post #6 of 29 (permalink) Old 18th December 2016, 19:55 Thread Starter
@Mr_JP looking for stupid people, its CN360 , this design is only made by cn360 , and is many reseller's. Original price is https://www.alibaba.com/product-deta...564081355.html 40$, if you order 500, they will put you logo, you box and so on. And its total glare. Look my post.....
post #7 of 29 (permalink) Old 18th December 2016, 22:24
Lithium Flower
Grayfox's Avatar
These are the ones JP sells.
https://www.aurorabulbs.com/collecti...nt=10675313475
They are not the cheap ones found on chinas ebay, the min order is 1.
You also cant compare glare just cause they look similar or because you saw one cars headlight make it glare.
You need to compare the same product on the same car as each cars headlights are designed differently internally.
post #8 of 29 (permalink) Old 19th December 2016, 06:43 Thread Starter
Oh yes, they probably charms, miraculous way will not glare, he made them and China copied from him . https://www.aliexpress.com/item/1set...5-2db8fd866695
are you joking ? Purchases from China and lying magical quality then resale, do you believe it ? The funny business is buy, sell for the double price.
post #9 of 29 (permalink) Old 22nd December 2016, 11:41
Would like to go LED too but not sure about the beam pattern in the stock housing. I think I'll wait until I see a forum user's experience with a set first
logiczero is offline
post #10 of 29 (permalink) Old 22nd December 2016, 15:05 Thread Starter
I ordered G7 CN360, and BT G10F , will compare them. The fact is that, thay BT (G9-G10) coped Click the image to open in full size. philips h11 fog ones, and used philips chips, 2nd ones, who are in Click the image to open in full size.
And thay use 3 of them, not like G7 (use 4 of them) , 3 is the top that reflector can hold in, and its are 2gen original philips chips.
post #11 of 29 (permalink) Old 3rd January 2017, 16:58 Thread Starter
So i got the G10F, puted h7 h1, will start from h11
Small, driver , metal,
How it looks?
Clean install
6000k
proper cut off, low glare
ante00 likes this.
post #12 of 29 (permalink) Old 6th January 2017, 00:51
Lithium Flower
Grayfox's Avatar
No offense but that is not a proper cut off
That is a big hot spot with a bad cut off and you will fail a MOT with it.
This a good cut off(RHD car)(LHD will be the same but mirrored) with halogen bulbs.
The camera only makes it look white due to the auto white balancing.
If you compare both beam patterns
Yours is an oval hotspot with bleeding on the sides and kick up going to the left and right.
Stock is a flat line with a 20 kick up which will point to the passenger side.
Skomaz likes this.
post #13 of 29 (permalink) Old 6th January 2017, 07:17 Thread Starter
Of course with halogen bulbs will be better cut off, that i was trying to told you ages ago. When there was a discussion about HID. Hologen has <1500lumen, this led 3150lumen. Need to readjust right headlights led lamp holder. Left is ok.
post #14 of 29 (permalink) Old 8th January 2017, 12:21
Did the H1 cover close normally? For the H7 there is space but I thought that the H1 cover was way too small for the LED.
warhawk is offline
post #15 of 29 (permalink) Old 8th January 2017, 17:28
Fergiem123's Avatar
Just fitted Mr JPs H7 LED kit, easy enough to fit, takes a bit of fiddling to get the drivers in and the headlight cap back on.
First impressions are very good. I had 5000k after market HIDs installed but the LED kit is whiter and so much brighter in comparison.
Waiting on full darkness to see what they're like on the road.
Big thanks to MrJP and Aurora Bulbs
Fergiem123 is offline
post #16 of 29 (permalink) Old 9th January 2017, 07:45 Thread Starter
Yes i did. Its more more than necessary.....
post #17 of 29 (permalink) Old 10th January 2017, 21:37
Photos please! I'm waiting for an OPT7 Fluxbeam H7 set to deliver...
warhawk is offline
post #18 of 29 (permalink) Old 10th January 2017, 21:44
I was betting money that it wouldn't. Thank god I didn't :P
I am thinking of ordering another H1 OPT7 Fluxbeam set for the main beams but I think I'm gonna wait for the H7 to arrive first.
LEDs are a very expensive sport. I 've change all internal lighting / side lights / tail lights exept turn indicators with Philips LEDs. All Philips + OPT7 H7 = ~300
warhawk is offline
post #19 of 29 (permalink) Old 10th January 2017, 22:32
Fergiem123's Avatar
Not had a chance to see what they're like on the road yet.
2 reasons;
1. Had to work in Wales at short notice
2. My wife drives my Civic now
Still don't know how to add a pic in a post anyway
post #20 of 29 (permalink) Old 11th January 2017, 20:14
I have patience
warhawk is offline
  Civinfo > 8th Generation Euro Honda Civic > Lights
Human Verification
HID new hid-led side lights and led fog lights darrellpope Lights 11 16th October 2012 16:12
