Having just stripped the front off the car using the very helpful 'how to' on here I found out that the previous owner has cut off the 2 connectors for xenon headlights (one to ballast and one to the headlight) to replace with a standard halogen headlight connector. The wires are still there but they've been cut to accommodate the new connector so it won't be hard to rewrite the correct connectors on!
Unfortunately I bought two xenon headlights to fit so this is useless for me!
Does anyone know where I could buy these connectors?
I'm trying breakers yards with no luck and Honda will only sell me the whole look for around £600!
Thanks for trying, unfortunately that's the sensors that are on each wheel to self level the lights. What I'm after is the connector that goes into the HID ballast under the headlight and the headlight connector itself.
No there isn't any hidden ones. For lights is in drivers footwell.
Soon when a bit warmer days come I'm converting my civic from halogens to xenons with all oem parts. Few days ago got all the bits (washers) and rest I got quite a long time ago but never had chance to install it.
Luckily my car had the self levellers already but I installed a new bumper and washers to be ready for the HIDs. It'll be a much nicer look once it's done!
Hi all this is my first post so greetings all. What's involved in the conversion to xenon from halogens. I have a donor car with xenon factory kit, is the harness the same or will it need adapting? What else is required, I understand I will need to fit the load levellers are the wires there to put onto the car or will I have to add wiring? Also how does the high pressure washer differ? I thought they only work above a certain speed?
I'd appreciate any input here as I'd love have this Improvement. Has anyone written a guide on this that I can't find?
Related Threads
2006+ Honda Civic Forum
2.5M posts
103.9K members
Since 2006
