This thread is about: Auto dim ambient blue lighting, it's in Lights at the Honda Civic forum Civinfo; IT`S ALIVE, IT`S ALIVE!! I use a relay and 330 ohms resistor for dimming. Diode on my circuit is problabe wrong way? http://www.youtube.com/watch?v=AsyUU49f6sU...
Old 29th May 2007, 16:47   #61 (permalink)
John Smith's Avatar
John Smith is offline   Reply With Quote
Old 29th May 2007, 17:04   #62 (permalink)
sco77harris's Avatar
im confused - where is this for too - and if it works will you make and sell some
Old 29th May 2007, 17:11   #63 (permalink)
John Smith's Avatar
Like the thread says , its for Auto dim ambient blue lighting ? Like Civic original, its dimming with interior and stays dimmed with headlights.
Old 29th May 2007, 18:41   #64 (permalink)
jeroen0302's Avatar
Nice John,
But do the int. lights, dimmed so fast? (I don't have my car yet, so i don't know what the normal time is.)
And de footwell leds are now connected thru the int. light circuit and the head light circuit? I stil hope there is easier way for a non-electrical guy LOL.
jeroen0302 is offline   Reply With Quote
Old 29th May 2007, 18:54   #65 (permalink)
John Smith's Avatar
Originally Posted by jeroen0302 View Post
Nice John,
Of course it is, go to dealer and get the original
Old 29th May 2007, 19:06   #66 (permalink)
jeroen0302's Avatar
Yeah and 300 euro lighter.
Old 29th May 2007, 19:21   #67 (permalink)
John Smith's Avatar
You may come to Estonia and buy for 190eur
Old 29th May 2007, 19:59   #68 (permalink)
4gotten's Avatar
In Germany it is available for 152 Euro. As every genuine extra equipment it is delivered with instruction "how to". I think with a very basic electric knowledge everybody can fix it. Have a try
4gotten is offline   Reply With Quote
Old 29th May 2007, 20:00   #69 (permalink)
Bog
Bog's Avatar
Very good John, I have couple of questions....
1. When you say 'A 330 ohms resistor for dimming' do you mean for reducing the light level when connected to the sidelights/glovebox light?
2. Do they dim from full brightness with the int. lights after the doors have been closed.
3. Can you do an updated circuit diagram?
I too have used PC fan connectors in my setup so the footwell trims can be removed easily....
If your circuit works, then that's the final part of my setup complete. ('How to ' to follow soon!)
Old 29th May 2007, 20:59   #70 (permalink)
John Smith's Avatar
1. Yes
2. Yes, as you see on video
3. Done, I don’t know diode, find it in old radio?
And write a good How To, for my is too much struggling with the dictionary
Old 29th May 2007, 23:27   #71 (permalink)
off to estonia i am
Old 30th May 2007, 10:27   #72 (permalink)
crispy's Avatar
Bog,
When you do your how to, can you tell us what wires you took from where, and also where you got your relay from. I think this is a neater solution than my 2 led circuit solution so I wil update it as soon as I can see your how to!
Regarding the resistor, I recommend a variable resistor mounted somewhere accessable so you can change the brightness of the LED's or turn them off completely.
crispy is offline   Reply With Quote
Old 30th May 2007, 10:51   #73 (permalink)
Bog
Bog's Avatar
Originally Posted by crispy View Post
Bog,
Will do! I think maplin do a relay that will be suitable, I'll have a look tonight.
I was planning to take the sidelight feed from the glovebox light and the int. light feed from the 'green wire' mentiond here by Stef in his PDF document. The only thing is, I'm not sure if this a PWM feed (Stef can you help?).
Old 30th May 2007, 23:36   #74 (permalink)
The Phantom's Avatar
WooHoo!
Can't wait for the 'How to guide'.
Been looking at this thread for a while wondering if it was ever gonna be solved.
The Phantom is offline   Reply With Quote
Old 5th June 2007, 22:48   #75 (permalink)
gray52's Avatar
That Is Alot Of Messing About, Just Use The Wiring From The Centre Console In The Roof, Then Use 2 Set Of Lights, 1 For The Doors And One For The Lights, Then You Have The Best Of Both Worlds, Put In A Dimmer And Its Better Than Hondas Set Up.
Old 5th June 2007, 23:25   #76 (permalink)
John Smith's Avatar
It is matter of taste. For my two sets LED strips is 20 £ and with realy is 12£, and it work like original?
Similar Threads for: Auto dim ambient blue lighting
Install Ambient Blue Lighting (Switched on by Main Lights) tamar How To 34 20th July 2008 07:55
Interior Ambient Lighting Griffyn Lights 34 6th January 2008 20:40
Interior Ambient lighting bonzo Lights 5 9th November 2007 13:06
Blue Ambient footwell lighting Primuldak Wiki Article Discussion 0 5th September 2007 19:42
Interior Ambient Lighting Kit Milano_Jon Lights 18 28th August 2007 23:57
