This thread is about: [Fog] Front fog lamp - smashed, it's in Lights at the Honda Civic forum Civinfo; I checked the lamp and its sort of loose, so I guess it got hit by a rock or somthing. The dealer here said that ...
LinkBack (3) Thread Tools Search this Thread Display Modes
Old 16th January 2007, 14:03   #101 (permalink)
tomas72's Avatar
The dealer here said that they havent had anyone come in with a smashed foglight before. The price for a new one is 3000,- Nkr which is about 250 GBP. Kinda expencive. Oh well, I'll get it fixed next friday.
tomas72 is offline   Reply With Quote
Old 16th January 2007, 14:16   #102 (permalink)
These lamps are £199.00 for the full fitting kit including TWO fog lamps in the UK!
audijohn is offline   Reply With Quote
Old 16th January 2007, 16:34   #103 (permalink)
shrimpman's Avatar
the ones i had fitted at the dealer do seem to be a "soft" fit
so maybe they were aware of the problem
shrimpman is offline   Reply With Quote
Old 21st January 2007, 22:55   #104 (permalink)
Diesel Demon
damianscott71's Avatar
Just to touch on a point that someone else made earlier in the forum, I think that the triangular shape of the foglights may be contributing to their troubles. Way back a long time ago, De Haviland, an aircraft manufacturer in the UK made the Comet, one of the first Jet airliners. It had great big square windows that gave the passengers an excellent view. However, after a few of the aircraft broke apart mid flight, De Haviland though to themselves "Hang on, this isn't right". So they took a plane, and tested it underwater while they pressurised the interior of the plane with air. They noticed that stress fractures appeared at the edge of the windows. This is what had caused the problems. That's why all moderm aircraft have small rounded windows. Also, that's why ships have rounded portholes. (It's probably why your bumhole isn't square too).
Thanks to my wife for the book "Why Don't Penguin's Feet Freeze", for the explaination to this conundrum.
In a similar way, the shape of the foglights is contibuting to their poor robustness. Also, the glass is very thin..... They need to use coated polycarbonate that is 250 times stronger than glass.
Damian
Old 22nd January 2007, 06:11   #105 (permalink)
Exactly
If they go on mine (when I get it) I'm fitting blanks till they sort it.
Thin glass down there is asking for trouble. When I look at foglights on other cars the glass is usually not as crystal clear as the headlights so must be a different type of glass.
Kremmen is online now   Reply With Quote
Old 22nd January 2007, 07:37   #106 (permalink)
Originally Posted by damianscott71 View Post
Number broken: 2
Age of car: 6mths
Mileage:18000 miles
When driving, or "it just appeared": It just appeared
Cost of replacement: Not done yet, approx £200 per side from dealer, £169+VAT per pair from spares company
Picture (attach)
If we don't get any satisfaction from Honda, I'll get in touch with Which Magazine (I'm a subscriber) My breakage patterns are exactly the same as those pictured elsewhere.
Yes your braekage pattern is not consistant with stone hits, before allowing them to be removed check if they are "floating" or jammed against the bodywork, I think you will find they are "immoveable" which is a fitting error from the factory.
Old 22nd January 2007, 15:46   #107 (permalink)
Diesel Demon
just bought an offcut of Macrolon polycarbonate. 250 times stronger than glass, but only 200 times more expensive! Not really, a 600mm x 200mm strip cost me a tenner. I should be able to make 4 lenses in scratch resistant polycarbonate.
Just need to get the pattern now. I think that drawing my own might be a bit wibbly-wobbly.
Does anyone know how to get the fog lamps out? I'll need to clean & dry them before fitting new lenses.
Ta,
Damian
Old 22nd January 2007, 16:24   #108 (permalink)
PTR
PTR's Avatar
Originally Posted by Kremmen View Post
Exactly
yes different type of glass because it is plastic!
I can't understand why isn't the fogliht plastic also.. then it would have a good stonechip resistance.. compared to glass
Old 22nd January 2007, 21:32   #109 (permalink)
Old enough to know better
Tony Fendall's Avatar
Damian,
Am I reading this right, you are making new lenses? Are you planning to remove the glass and fit Makrolon?
I think it would melt, but I may have this all wrong.
Where are you getting your material for £10 because I want some to make covers from 1.5mm polycarbonate, Velcroed on.
Regards
Tony
Tony Fendall is offline   Reply With Quote
Old 22nd January 2007, 23:20   #110 (permalink)
Diesel Demon
Hi Tony,
That's right, I'm making new lenses out of 4mm coated polycarbonate.
Polycarbonate won't melt. It's the stuff that manufacture make headlights out of anyway.
If anybody needs 2mm polycarbonate to make a cover, I can supply a strip big enough to make about 6 covers for £10 plus postage, along with a pattern for you to cut out.
Polycarbonate sheeting can be cut using a handsaw, jigsaw, hacksaw, possibly even tin snips at low thicknesses. Rough edges can be dry sanded and clean edges can be wet sanded to improve the finish.
PM me if you're interested.
Damian
Old 23rd January 2007, 09:57   #111 (permalink)
gray52's Avatar
i have 1 pair of fog light covers all ready made, inc fixings to the fog light and the cover can be removed for cleaning etc.
pm me if interested, paypal accepted.
Old 23rd January 2007, 10:19   #112 (permalink)
您看了
CivPilot's Avatar
Got some of Gray's fitted and they are well worth the money. very sturdy, well cut and finished and blend in nicely
Old 23rd January 2007, 20:14   #113 (permalink)
NickG's Avatar
I don't know why people keep posting saying "fog lights never break on other cars so why do they break on the civic" (or similar). I've seen loads of broken fog lights on other cars!
On my Ford Focus, I got through 4 of them in a year and then decided not to replace them anymore until it was up for sale. I haven't driven it since then and they're fine My girlfriend has a Renault Megane and both lights went in a few weeks and we've elected not to replace them on that car either until we can get some polycarb covers fitted.
The Focus's foglights are MUCH more sturdy than the Civic's. The front glass is really thick and they still break just as often as the civic's. It's not heat damage as some people are suggesting (do you have any idea how much temperature difference you need to crack glass?! You pretty much need a blowtorch and some ice. The piddly little 30W bulbs are never going to get the glass hot enough to crack it - besides - most people have said they were off at the time). I'm quite positive that the smashed lights are caused by stones at high speed. A 1 pence piece thrown casually at the center of a light breaks it (yes I did this accidentally by a very unlucky co-incidence when I kicked a penny on my drive!!) so what do you think a small stone at 50-90MPH will do? Anything larger than a pea at 40+ mph will definitely crack the glass.
NickG is offline   Reply With Quote
Old 23rd January 2007, 20:19   #114 (permalink)
gray52's Avatar
nickg u have a pm regarding fog light covers.
Old 23rd January 2007, 21:14   #115 (permalink)
Nick,
You are not entirely correct; a couple of the pictures in the forum are clearly stone damage, but the majority, including mine, were due to a stress issue.
I was driving along a deserted country road when there was a 'crack' from the front of the car; on reaching my destination the offside fog light glass was broken.
The issue was recognised by Honda as not being stone damage and my repair bill was repaid in full.
Read back in the forum and you will find one owner with two lamps gone in the first week of ownership; all paid for by Honda.
Furthermore, in 45 years of car ownership I have only had one other fog light glass broken and that was stone damage on a Vauxhall Calibra, I guess that makes me very lucky in your book.
Regards
Tony
Old 24th January 2007, 12:40   #116 (permalink)
Damian,
I fully understand what you are doing to your fog lights and the new lenses you are making and why you are doing it, however, manufacturers spend a great deal of time designing lamp glasses.
I am sure you will have no more breakages, but you will not be able to see very well in fog either.
All those little prisims are built in to give correct beam cut off and to keep them legal.
If a manufacturer tried to sell a car with fog lamps with clear covers, they would not get the car homologated for sale in the UK.
Regards
Tony
Old 24th January 2007, 13:02   #117 (permalink)
NickG's Avatar
What prisms? Sorry but this is total rubbish and you clearly either don't have a Civic or have never looked at it's fog lights.
As with most cars, the Civic's fog light light spread pattern is controlled by the rear reflector. The front glass is plain glass and the light distrubution pattern is totally unaffected by it. There are no "little prisims" (or prisms as it's correctly spelt) on a Civic's fog lights as you can easily see for yourself.
What ARE you talking about? Nearly all new cars going back to the 90's have completely clear glass in their headlights and foglights. The front glass has no effect at bending or controlling the spead pattern. I have to go back 20 years to think of a time when we had a car where the front glass actually did any focussing.
Old 24th January 2007, 14:47   #118 (permalink)
You are totaly wright; the beem control is dun by the reflektor not by the glas as fist it apears.
My apppologies.
Many of my previous cars had beam control by the glass.
Regards
Tony
Old 24th January 2007, 15:16   #119 (permalink)
NickG's Avatar
Does that include the one in your avatar picture?
Old 24th January 2007, 17:18   #120 (permalink)
Absolutely right; those foglights cut through fog like a knife.
But just for an additional laugh; a friend of mine at college was giving me a lift home one night in an Austin 7 and the fog was so bad we jumped out of the car, opened the drivers window, set the hand throttle to idle and walked home alongside the car with hand on the wheel.
They were proper fogs in the late 60's.
Tony
LinkBack to this Thread: http://www.civinfo.com/forum/lights/467-fog-front-fog-lamp-smashed.html
www.clubhondacivic.com :: Ver tema - La mierda de lluvia = 250€ aprox... This thread Refback 23rd April 2008 14:59
Nebelscheinwerfer a'la Honda.... : Honda Civic FK, FN, FD This thread Pingback 10th March 2008 17:50
Fendinebbia scoppiato - Luci This thread Refback 17th November 2007 14:21
Search this Thread:
Advanced Search
Similar Threads for: [Fog] Front fog lamp - smashed
Smashed fog lamp? - register here Pottsy Lights 99 14th May 2008 08:19
Someone smashed my mirrors illegalhunter Type-R 33 6th November 2007 18:45
Front Discs and Pads and drivers side fog lamp for 2.2 EX sonicsteve Holdcroft Honda 1 10th July 2007 08:57
Window smashed by vandals Willie General Discussion 51 16th February 2007 11:35
Front fog lamp - slightly used richierich For sale and Wanted 2 1st August 2006 15:50
