| This thread is about: Lights FAQ, it's in Lights at the Honda Civic forum Civinfo; The Civ manual is incorrect when it comes to bulb types:. On cars without HID , it's H1 for the main beam, and H7 for ... | ||
Lights FAQ
On cars without HID, it's H1 for the main beam, and H7 for dipped. On cars with HID dipped beam, it's H1 for the main beam. To install fog lights, click here [HOW-TO] Install fog lights To change headlight bulbs, click here: [HOW TO] Replace headlight bulbs & front position light You can get 10% off at Autobulbsdirect here. |
For a list aftermarket bulbs that owners have experimented with, and their comments, please click here
I am probably being really stupid, but I am thinking about getting diesel sport which comes with HID.
Why, according to the list above, is the HID only on dip - does HID not do full beam also? |
No main beam is a normal Halogen bulb as they light up quicker so work better for flashing. On main you have the dip on as well so main just adds to the light out put ans extends the range.
No it isn't. There are two types of HID-headlamps: one were only the dipped beam is HID, main beam and flashing is halogen. The other has one HID-lamp for both dipped and main. I think in this type the voltage to the lamp makes the difference between dipped en main. With this type there are two possibilities for flashing: some cars have to flash with the same HID-lamp, other have an extra halogen lamp for flashing.
Craig I found the same, some of the sites are a bit off when it comes to bulb fitments, I believe some civics do use the other fittings? according to the other philips fitting guide from the site below (hopefully that is correct!). Sorry if I'm wrong
If you go to http://www.autobulbsonline.co.uk then just keep in scrolling down (like your looking for the end of the earth, you will then find a link at the bottom to the Philips bulb fitment guide), not sure why it's hidden down there. |
#12 (permalink) |
Dandy Don
Sorry to sound like a daft bugger, but what is HID?
Never mind,found it in the Wiki! Last edited by StuMcBill; 28th January 2008 at 19:48. Reason: Found it! |
| Indications Eco lights | bounce75 | Engines and Transmission | 37 | 3rd August 2007 13:57 |
| Bulbs Wot Lights??? | tonyt | Lights | 1 | 9th January 2007 13:38 |
| Engine REV Lights | psiboy | Bugs, faults and irritations | 17 | 16th December 2006 16:10 |
| Interior map lights | mihael | Lights | 1 | 1st October 2006 02:10 |
| Head ES Lights | kevin_lufc | Lights | 77 | 7th September 2006 18:32 |
