This thread is about: [Indicator] wing mirror bulbs, it's in Lights at the Honda Civic forum Civinfo; I have a 2006 ES Near side wing mirror turn repeater not working how can i check if its the bulbs? Checked hand book on ...
Old 25th April 2007, 17:57   #1 (permalink)
I have a 2006 ES
Checked hand book on mention on how to replace bulbs.
Any info appreciated.
Smugger
Smugger is offline   Reply With Quote
Old 25th April 2007, 18:21   #2 (permalink)
do the front and rear indicators flash, just not the wing mirror ones?
and - can you adjust the mirror? - ie might be a loose connector block.
and welcome aboard by the way !
Old 25th April 2007, 20:13   #3 (permalink)
Bungle's Avatar
I thought the lamps in the mirrors wer LEDs....
Old 25th April 2007, 20:47   #4 (permalink)
Thanks for responce
Yes to both questions mirrors retract and can be adjusted and both fornt and back indicators work.
Old 25th April 2007, 21:26   #5 (permalink)
Bog
Bog's Avatar
Yep, I thought they were LEDs too!
Old 25th April 2007, 21:55   #6 (permalink)
I too believe they are (multiple) LEDs - which was why I was going down the route of checking electrics
However.
Whilst the manual doesn't specify which fuse covers the indicators (under bonnet fuse 22 is hazards), the fact that the front and rears work seems to rule out a blown fuse.
Working electrical mirrors also seems to rule out a loose connector block (though I guess it might just be hanging on in).
Which would - again seem - to indicate (sorry!) the bulb(s)
TTDegs wanders off to think some more...
Old 26th April 2007, 06:27   #7 (permalink)
How do i get the cover off to check bulbs/led's ???
Old 26th April 2007, 07:13   #8 (permalink)
From memory isn't it a bank of 6 or 9 LED's ?
If so then it's likely a power issue rather than blown LEDs, unless they are wired in series.
Sounds like a dealer issue to me as it must be covered by warranty.
Old 26th April 2007, 08:15   #9 (permalink)
martin051169's Avatar
Hi Smugger, Recently had to change my passenger side mirror indicator due a another errent stone on the motorway smashing the lens ...it is a sealed led unit with 3 leds, cost is £45.10. It is possible that water from cleaning the car has got is also and got into the block connector mine had and the connectors pins were green instead of copper!!! getting to them can be a bit of a lottery, it is simple but if done wrong you can also break the mirror cover which i was informed by the dealer.....decided to do it myself and was a 5 minute job.... first used a plastic knife to prise the underneath of the mirror cover off and then slowly work your way round the mirror to loosen it....then simply pull the whole cover forwards with a bit of 'jiggling' to help!! but please be careful as if too heavy handed the cover clips can break and this will result in a new cover being required also . LED unit is secured with 3 hex screws. Easy job to be honest but most dealers will probably do the fitting for free if a new unit required. Hope this helps and good luck
martin051169 is offline   Reply With Quote
Old 26th April 2007, 08:16   #10 (permalink)
This is where the service manual would come in handy
Old 26th April 2007, 08:42   #11 (permalink)
or failing that, a decent forum full of people who have "been there, done that"
Old 26th April 2007, 08:48   #12 (permalink)
Bog
Bog's Avatar
Perhaps we could Martins post moved to the 'How to' section?
Old 26th April 2007, 09:11   #13 (permalink)
good call - done
Old 26th April 2007, 09:25   #14 (permalink)
Hi Thanks martin 051169 for info
as its still under warrenty i am not going to take a chance of breaking anything and i am taking it back to my dealer to-morrow.
Will post outcome especially if it's a possible commom problem.
Old 26th April 2007, 10:36   #15 (permalink)
Stef's Avatar
Here a picture of the italian manual
Strange that first they mention to remove the mirror glass,
But then on this picture the glass is still visible, so like Martin indicates, it seems possible to remove the cover without removing the glass.
Old 26th April 2007, 10:43   #16 (permalink)
cheers Stef - I'll merge a copy of that into the How To too
Old 28th April 2007, 06:59   #17 (permalink)
Turns out that the indicator is faulty so it's under warrenty and have to wate untill they get one in.
Thanks everybody for your help.
Old 30th April 2007, 17:08   #18 (permalink)
good news smugger!
(well, not good that it's bust, but good that they're fixing it )
Old 17th July 2007, 08:15   #19 (permalink)
Skippy's Avatar
Another mirror indicator failure
Yup, my nearside mirror indicator has failed. Oddly, it became intermittent before failing completely.
Replaced quickly without quibble by the dealer. Only a few finger marks to get off the mirror!
Skippy is offline   Reply With Quote
Old 15th November 2007, 17:00   #20 (permalink)
GerryJ's Avatar
My passenger mirror indicator failed, also replaced without quibble by the dealer.
GerryJ is offline   Reply With Quote
Search this Thread:
Advanced Search
Similar Threads for: [Indicator] wing mirror bulbs
Wanted - Wing mirror Jedi71 For sale and Wanted 2 24th October 2007 20:56
How do i get the wing mirror cover off mike_GT General Discussion 2 6th June 2007 14:38
Type S GT Replacement wing mirror mike_GT General Discussion 7 31st May 2007 10:38
[How To] get at the wing mirror bulbs martin051169 How To 1 26th April 2007 10:36
Replacement wing mirror NickG Bugs, faults and irritations 5 26th January 2007 09:31
