This thread is about: Third rear Brake light, it's in Lights at the Honda Civic forum Civinfo; Does anyone know if anything can be done to make the third brake light look better from a distance Think I asked somthing similar before ...
Old 7th May 2007, 23:17   #1 (permalink)
Perfect Guy!
Brodick's Avatar
Think I asked somthing similar before we had our civic and it was a case of yeah it's a bit naff isn't it
It does work and looks fine right up behind another civic but from a distance it looks like it is knackered
( and before you start TC - don't this is not a complaint in any shape or form - more a observation and a query as to whether somthing can be improved)
Old 8th May 2007, 10:27   #2 (permalink)
I don't know, this has been mentioned before. Sometimes the whole bar isn't illuminated. Different cars seem to light up differently. Guess it's the way the light is reflected within the lamp.
Old 8th May 2007, 12:35   #3 (permalink)
Are they led's in the display?
They are very concious in which direction they show their brightness I believe.
Several Civics that I've seen often look as though they have variations of intensity in that display.
Can't report on Millie tho' I put the brake on and by the time I get around to the back to have a look the lights gone off again!
"Would you like the violinist to play anything in particular? Dominoes perhaps!"
Charles H.
Old 8th May 2007, 21:14   #4 (permalink)
No there not LED's. I haven't noticed any differences between third rear break light on Civic's, they all look bright enough to me
Wouter is offline   Reply With Quote
Old 8th May 2007, 22:48   #5 (permalink)
Perfect Guy!
Brodick's Avatar
If you put something on the brake pedal or ask someone to press it down
whilst you look at it you will see a perfect shining brake light
but out on the open road if you are a little distance away from another civic infront of you it looks as if the brake light is not working properly
I think CZ may be on the right lines
I also think LED's would have been a much better idea
Old 9th May 2007, 21:08   #6 (permalink)
ante00's Avatar
i think third stop light is led lamp...it sais in manual........
2Brodick: i saw on italian forum that some guy removed red plastic around light ;result:shines more and looks better......sorry i don't have pics because they removed them.........i'll contact them to send me pics
Old 9th May 2007, 21:28   #7 (permalink)
There are 4 LEDs - I wonder if they just point in different directions....
Old 10th May 2007, 13:39   #8 (permalink)
I was behind a Civic the other day and checked this out. As Pottsy says there are 4 LEDs. Now the red brake light cover appears to be wide enough for at least 20 LEDs.
So Unless you are right behind it when the light can spread out into your vision it will look like most of the light does not work, which in effect with just 4 LEDs in the middle of the light is correct.
I am sure Honda saved at least 3p per Civic putting less LEDs into the brake light.
Cheltenhamshire is offline   Reply With Quote
Old 13th May 2007, 10:09   #9 (permalink)
ante00's Avatar
yesterday i opend third stop light and there are 6 LEDs int the middle.......did anybody notice that right side is different from left? (right is stronger light)....when you look it from back or driving behind civic
Similar Threads for: Third rear Brake light
Brakes Replacing Front and Rear Brake Pads (merged) Miggins Wheels, Tyres, Suspension and Brakes 46 9th August 2008 21:09
front and rear brake pads? valmiki Holdcroft Honda 13 10th September 2007 15:56
Brakes Rear Brake Disks ricky_west Wheels, Tyres, Suspension and Brakes 8 6th July 2007 20:39
Lights Water under rear light lens. GerryJ Bugs, faults and irritations 11 6th December 2006 13:23
Brake Centre Brake Light ? belliowalnut Lights 9 27th November 2006 13:59
