Go Back   Civinfo > 8th Generation Euro Honda Civic > Lights
Old 23rd September 2011, 20:34   #1 (permalink)
Ash_TypeR's Avatar
Car: 2007 Milano CTR GT
Thanks given: 5
HID fitting Type R
Hi pepole. Ive just bought myself a MR JP kit off another forum member. Can anyone clear up for me a slight issue I have. The HID kit has a blue cable and a black cable, that connect to your original bulb connections, can anyone clear up which colour cable connects to which colour on your original light fittment? (If that makes sense lol)
Ash_TypeR is offline   Reply With Quote
Old 23rd September 2011, 20:54   #2 (permalink)
rossk1009's Avatar
Car: 58 NHB TYPE R GT
Thanks given: 145
Not sure what wire it connects to but blue on the hid kit is positive. is on of the connectors from the car a yellow one?
Yellow rings a bell for some reason
rossk1009 is offline   Reply With Quote
Old 23rd September 2011, 20:58   #3 (permalink)
Ash_TypeR's Avatar
Thanks given: 5
Only got the kit this evening so not looked under the bonnet mate, but looking at loxys' guide his type r has brown and yellow connectors so I can only assume mine would be the same. So yeah I imagine one will be yellow! If so you think blue to yellow and black to brown?
Old 23rd September 2011, 21:07   #4 (permalink)
rossk1009's Avatar
Thanks given: 145
Originally Posted by Ash_TypeR View Post
Only got the kit this evening so not looked under the bonnet mate, but looking at loxys' guide his type r has red and yellow connectors so I can only assume mine would be the same. So yeah I imagine one will be yellow! If so you think blue to yellow and black to red?
If you have a voltmeter then test it to make sure. Either that or I will look at mine tomorrow morning and let you know for certain
Old 23rd September 2011, 21:14   #5 (permalink)
Ash_TypeR's Avatar
Thanks given: 5
I dont have one unfortunately. Ohhh if you could that would be brilliant mate!!
Cheers.
Old 24th September 2011, 11:17   #6 (permalink)
rossk1009's Avatar
Thanks given: 145
Just checked mine
Blue - yellow
Black - brown
I was sure yellow went to blue but better making sure
Thanks to rossk1009 from:
Old 25th September 2011, 12:35   #7 (permalink)
Ash_TypeR's Avatar
Thanks given: 5
Thanks mate!
Old 25th September 2011, 13:19   #8 (permalink)
Jenga_89's Avatar
Car: 2008 Milano CTR
Thanks given: 96
All i can say is good luck fitting the passenger side lol
Jenga_89 is offline   Reply With Quote
Old 25th September 2011, 13:49   #9 (permalink)
rossk1009's Avatar
Thanks given: 145
Its definitely a battery out job
Old 25th September 2011, 14:05   #10 (permalink)
Jenga_89's Avatar
Thanks given: 96
I had to take my ecu out aswell to get the cold air feed back in..... i was ready to cut of a few fingers so i could get my hand in!
Old 25th September 2011, 14:22   #11 (permalink)
rossk1009's Avatar
Thanks given: 145
I know what you mean. I sat the cold air feed in boiling water for half a minute and it went back in quite easy so didn't have to remove the ecu
Old 25th September 2011, 20:06   #12 (permalink)
Foulsmell's Avatar
Thanks given: 55
When you take the rubber cold air feed out just put a little grease around the bottom and it goes back on easily.
Foulsmell is offline   Reply With Quote
Old 26th September 2011, 07:41   #13 (permalink)
murray's Avatar
Car: CW Civic FD2
Thanks given: 155
I was lucky I only had to take out the rubber cold air feed pipe which I no longer used. I came a little annoyed fitting them when fitting the drivers side and the spings clip thing which holds the lamp in popped off. Trying to clip the two prongs back in while getting dark wasnt the best.
Finally got them sorted after 30 or so mins just with this one clip... If I was to do this again, do NOT start when you only have 20 or so mins of daylight left, but I hate waiting for things...
murray is offline   Reply With Quote
Similar Threads for: HID fitting Type R
question about fitting Type R knob on Type S Iiyama Styling 5 16th March 2011 08:27
Gap when fitting the Type R Kit? cHaZ RED CIVIC Styling 14 9th May 2010 20:33
Ireland type r fitting chrisoadamson Styling 12 17th January 2010 23:29
Fitting a Type S Grill jambo1984 Styling 6 17th September 2009 09:54
Suspension How to for fitting lowering springs??? Or cost for fitting? parsey Wheels, Tyres, Suspension and Brakes 4 29th March 2009 20:57
