This thread is about: Rear fog lights, it's in Lights at the Honda Civic forum Civinfo; Have just checked the rear fog lights on my 2.2 EX and only one appears to be working. Before I go to the dealer for ...
Old 19th June 2007, 22:44   #1 (permalink)
djm
Rear fog lights
Have just checked the rear fog lights on my 2.2 EX and only one appears to be working. Before I go to the dealer for them to sort it, can someone please confirm that there are supposed to be TWO rear foglights.
djm
djm is offline   Reply With Quote
Old 19th June 2007, 22:58   #2 (permalink)
In some countries it is not legal to have two rear fog lights.
Old 19th June 2007, 23:13   #3 (permalink)
in the UK, only one rear fog light, so all is as it should be
Unless you have a CTR, in which case the fog lights are moved, and I think you then get 2
Old 19th June 2007, 23:13   #4 (permalink)
pjr
pjr's Avatar
Depends what country you're in - If you're in the UK, then you will only have one fog light (on the right hand side)
Old 19th June 2007, 23:14   #5 (permalink)
Morris Minor's Avatar
Wink
Only one rear fog light fitted, in UK at least. It's already mentioned in a thread somewhere on the forum.........in the lights section I would imagine
MM
Morris Minor is offline   Reply With Quote
Old 19th June 2007, 23:21   #6 (permalink)
djm
I'm in the UK. I'm certain that my clio and corsa before this had 2 working rear fog lights. It just looks very odd to have only one light working.
Old 19th June 2007, 23:57   #7 (permalink)
although only in the fog, and even then, only if you get out and have a look
you're right though, would be more symetrical to have 2
Old 20th June 2007, 10:43   #8 (permalink)
djm
Yes I've just got to the lights section in the manual, about 400 pages in (are all manuals this long?!) and it's as you say, only one rear fog light.
Old 20th June 2007, 12:44   #9 (permalink)
tomtank62's Avatar
Has anyone looked closely at this, I had a car once with only 1 rear fog light? Investigations showed that all the wiring was in place for a second one, all I had to do was put a bulb in. I will maybe take a look later.
tomtank62 is offline   Reply With Quote
Old 21st June 2007, 11:25   #10 (permalink)
Smell My Cheese!
richierich's Avatar
I think it is better to only have a single light, from a distance in fog it does not look like a brake light.
Old 21st June 2007, 11:54   #11 (permalink)
HondaRob's Avatar
I have investigated and there is only space for one bulb. Bit sill really as it looks nicer with two.
My wife's old Clio had one bulb, but the wiring and holder for two (was duly upgraded), my PoS of a VW had the space for two and the holder, but the wiring (all of two wires) were not carried over form the main loom - pathetic.
Hoping someone can get the honda to have two sometime in the future...?
HondaRob is offline   Reply With Quote
Old 21st June 2007, 11:59   #12 (permalink)
The Doctor's Avatar
I had a 1986 Ford Escort which had 2 rear fog lights...
The Doctor is offline   Reply With Quote
Old 21st June 2007, 12:53   #13 (permalink)
Bog
Bog's Avatar
Richierich is right, in the UK it's to prevent it being mistaken for brake lights.
Have a look here. Stef has added the extra bulb to create additional rear lights
Old 21st June 2007, 22:35   #14 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
This has been covered in the past see Rear Fog Lights
If i remember correctly, you ca have two rear fogs in th UK if the position is correct. My last car (Rover 75) had 2 rear fogs.
Old 26th June 2007, 23:28   #15 (permalink)
St3ph3n's Avatar
My old Hyundai Coupe had 2 rear fogs and 2 reversing lights. My Civic and my old man's Accord only have one of each.
St3ph3n is offline   Reply With Quote
Old 26th June 2007, 23:40   #16 (permalink)
Perfect Guy!
Brodick's Avatar
Well your new civic wil have two reversing lights
but still only one rear fog
seems to be more and more cars nowadays with one rear foglight
Old 27th June 2007, 19:24   #17 (permalink)
Remember the same parts are essentially used for LHD & RHD cars, cheaper that way. So the Civic has two rear foglights but only one activates. If you were taking the car abroad you would just need to switch the wiring over.
It's not rocket science.
Old 27th June 2007, 23:56   #18 (permalink)
does that mean you're working on the How To for swapping fog lights over then CP?
Old 3rd July 2007, 09:07   #19 (permalink)
Smell My Cheese!
richierich's Avatar
Can't wait CP, thanks for that, any chance of it before the weekend, I'm going to Scotland!
Similar Threads for: Rear fog lights
Other type r rear lights oli_typesgt Lights 20 18th September 2007 17:37
Brake Rear Indicator Lights allan40alt Lights 61 30th June 2007 00:34
Brake Rear Lights Upgrades? DanKo Lights 6 6th May 2007 14:34
Lights Loose rear lights! DanKo Bugs, faults and irritations 2 9th December 2006 18:46
Fog Rear Fog Lights JPDirect Lights 17 5th November 2006 21:29
