This thread is about: Type-R With Replaced Headlights + PIC, it's in Lights at the Honda Civic forum Civinfo; Originally Posted by Mr JP Do the Phillips X-Treme + 80% H7 bulbs produce a brillaint white light or give off a blue tinge? Also ...
Old 5th July 2007, 19:17   #21 (permalink)
It wasn’t me!
Also has anyone tried Phillips Dimond Vision, these look like Bluevision but are 5000k not 4000k like the bluevision's.
White light
Old 5th July 2007, 19:39   #22 (permalink)
HACKIN & SLAYIN
Iam so getting them , another thing to add to the list.
Old 5th July 2007, 20:46   #23 (permalink)
i must be lucky i got a ex one year old and its the best ligts i ever had even better than my vauxhall van or any ford transit
allan79 is offline   Reply With Quote
Old 6th July 2007, 10:59   #24 (permalink)
Arnt the Xenons automatic levelling? If so, you will need software to adjust, or was that just on VAG cars?
they are self levelling, but there is an adjuster for the 'start point'
I've tried to put that in words, but failed
so here's a (rubbish!) pic instead
6 pics, 2 sets.
Set 1:
Pic 1) headlights as standard, hitting road 10 foot ahead.
Pic 2) 5 bags of cement, with no self adjusting going on - lights hit 100 foot ahead
Pic 3) 5 bags of cement, self adjust gets the light to hit back at 10 foot
Set 2:
Pic 1) headlights manually tweaked to hit 20 foot ahead
Pic 2) 5 bags of cement, so self adjust - lights hit the road waaay off in the distance
Pic 3) 5 bags of cement, self adjust gets the lights back to the original position of 20 foot ahead
hope that makes sense!
Old 6th July 2007, 11:02   #25 (permalink)
Doesnt headlight alignment get checked by the UK MOT?
Do you have a pic of the adjuster?
Old 6th July 2007, 13:35   #26 (permalink)
Mr JP's Avatar
Can anyone out there please tell me what temperature the philips x-treme + 80% bulbs burn at i.e the kelvin figure, my bluevisions are 4000k, are these higher?
Response appriciated!
Mr JP is online now   Reply With Quote
Old 6th July 2007, 15:10   #27 (permalink)
Vivid Blue Rocks!!!
Foggy69's Avatar
Unfortunately, there is no mention of the colour temp on the packaging or on the website that I can see.
But I don't think it as high as the Blue Vision bulb. They aren't supposed to be HID look-a-like bulbs, they are just brighter standard bulbs.
They are a worthwhile investment for the Civic though
Old 6th July 2007, 16:31   #28 (permalink)
AubreyS's Avatar
you definatly need new specs! thats why i specifically said look at the light perpendicular to the lamps directly above/below and it's bloomin obvious!
Anyways like I said, it is a massive improvement in performance with more light on the tarmac and thus potentially safer.
No thanks, my specs are fine. As long as you are happy with them, thats all that matters.
Old 11th July 2007, 22:26   #29 (permalink)
It wasn’t me!
They emit no more heat than a 'standard' bulb. They gain more light by the design/geometry of the bulb rather than making the filament hotter with more wattage, therefore they are fine to fit in any bulb holder. They are much much much better than 'normal' but are still white/yellowish
If Philips produced a Blue vision x-treme......even better. Maybe !!
Similar Threads for: Type-R With Replaced Headlights + PIC
Dash Replaced For Type R deeny Styling 7 17th June 2007 16:00
Trim Have you had your dashboard trim replaced? tooheys99 Bugs, faults and irritations 24 26th April 2007 09:04
Trim Side Curtain Airbag plastic cover replaced! vtecpower Bugs, faults and irritations 3 21st March 2007 16:03
Exterior Alloy Wheels being replaced under Warranty civicsport Bugs, faults and irritations 2 25th February 2007 19:20
Options HID headlights apd Buying, Dealers and Servicing 12 11th October 2006 04:36
