This thread is about: Blue light that shines on the gear stick, it's in Lights at the Honda Civic forum Civinfo; Afternoon Folks Just wondering if it is possible to replace the Blue light that shines on the gear stick with a brighter one. I've seen ...
Old 2nd July 2007, 15:30   #1 (permalink)
rhoworth's Avatar
Afternoon Folks
I've seen the posts that tell you how to replace the bulb but can't see if you can increase the brightness.
Ta
Robbie
rhoworth is offline   Reply With Quote
Old 2nd July 2007, 15:44   #2 (permalink)
Smell My Cheese!
richierich's Avatar
I am not sure about replacing, but I am sure someone either enlarged the hole, or moved it closer, in an attempt to increase brightness, I forget when, or whether it was a success, I have slept since then!
Old 2nd July 2007, 16:24   #3 (permalink)
ante00's Avatar
here is a link.....you have to use Search or just look in How To.....
How to change a led
Old 5th July 2007, 11:45   #4 (permalink)
It wasn’t me!
What light that shines on the gearstick? I dont seem to have one. Is this model specific??
Old 5th July 2007, 13:47   #5 (permalink)
Smell My Cheese!
richierich's Avatar
Between the 2 map lights in the front there is a small slit, a blue led is behind it, not sure if it is model specific though.
Old 5th July 2007, 13:52   #6 (permalink)
Which was my thought as well. So I had a look and you are right, there it is. I had noticed the light but hadn't realised why it was there. it really does give very little illumination which makes me wonder why it was fitted.
Old 7th July 2007, 15:02   #7 (permalink)
It wasn’t me!
Found it. The point of this is??????
Does it iluminate the gear stick?
Ive not driven in the dark yet to tell. Car only 2 weeks old
Old 7th July 2007, 15:17   #8 (permalink)
Parky's Avatar
If you are on a road with no street lighting then yes it does give some illumination, otherwise it's a bit of a waste of time.
Ian
Parky is offline   Reply With Quote
Old 12th July 2007, 11:56   #9 (permalink)
Red on the typeR obviously and it seems to work for me - as a gentle glow.
Perhaps the red spectrum is more noticeable than the blue ...
MoOriginal is offline   Reply With Quote
Similar Threads for: Blue light that shines on the gear stick
What is the Little Blue Light for? rtypeblack Wiki Article Discussion 20 30th August 2008 08:33
How much for the upgrade Gear stick in options mike_GT General commercial posts 7 18th June 2007 11:16
Annoying dirt round gear stick. czechplastik Cleaning 8 1st June 2007 23:41
Type-R gear stick? yorkshiregrit Styling 3 15th March 2007 22:10
Squeaks Plastic noise in gear stick : resolved Nanucq Bugs, faults and irritations 0 27th October 2006 08:44
