| This thread is about: Automatic cancelling of indicators, it's in Lights at the Honda Civic forum Civinfo; We are all familiar with the indicators turning themselves off after completing the appropriate turn, but on my Civic I have noticed that if I ... | ||
We are all familiar with the indicators turning themselves off after completing the appropriate turn, but on my Civic I have noticed that if I signal right and turn left, so that the steering wheel clicks the off switch, then my signal is cancelled even though I have not yet turned right.
I want to know if this is how all Civics behave or whether my car has a defect. I suppose many of you may not have noticed this problem, but as I live in Milton Keynes with it's masses of roundabouts it happens to me all the time. i.e. I am signalling to turn right and then I have to turn left to go around the roundabout. I certainly have not had this problem on my two previous cars. |
Mine does it too when I am going to turn right at a roundabout and have to signal before the short left-hand bend on the approach to the roundabout.
My previous cars all did it too so I hadn't even noticed it before now. |
Vivid Blue Rocks!!!
The Civic has a 'lane changing' facility on the indicators. If you just flick the stalk quickly it will indicate 3 times. Are you just flicking the stalk, seeing the car indicate and think it's locked into the direction you want it to indicate ??
I can't say I have noticed the behaviour you have described otherwise. |
#5 (permalink) | |
Vivid Blue Rocks!!!
I was thinking a bit more about this, and the only roundabout I regularly turn right at has a straight approach to it, so this is why I haven't noticed this behaviour. |
It doesn't happen too often, but it did also on my old Civic, and on my Corsa school car. I don't think it is a fault. I know I pre-empt it happening without thinking so as soon as it cancells I am putting it back on.
Thinking more, I know it happnes often after turning the wheel the same direction as the indicator, but not too sure about turning the other way...... |
Perfect Guy!
Had this in every car I have driven
Honda Daewoo Renault Peugeot etc any car should do this the system will cancel an indicator if you turn the opposite way |
#8 (permalink) | |
Harris Tweed
Anthony. |
Smell My Cheese!
The system is designed to do that, imagine making a right turn into a side road, as you complete the manouvre the wheel is turning left, there is a little mechanical device which cancels the signal, no different to indicating right and actually turning left.
I guess the important bit is to make sure you are indicating once on the roundabout,having your indicator cancelled when turning left on to it, a pain as it is, is not that much of an issueal. |
I've just picked up a courtesy 1.8 Type S from my dealer whilst they investigate my rear sun blind issue and it does it as well.
My previous cars that didn't were a 2001 Ford Focus and a 1990 VW Golf. I spoke to a colleague at work shortly after posting my query and he had the same feature on his Peugeot 307. I just found it an odd behaviour. |
#14 (permalink) |
Perfect Guy!
er you should indicate before you join a roundabout if you are taking the first exit or if your are going around the roundabout to inform the cars behind you and who may be following
#17 (permalink) |
Except when people indicate right which I am supposed to guess actually means "I am not taking the first exit" and then go straight on (at a 'standard' 4-way roundabout). Aaaaaaargh!
| Electrics Dashboard Indicators | PaulB | Bugs, faults and irritations | 15 | 24th April 2007 22:34 |
| Dealers Cancelling orders | SheepCivic | Buying, Dealers and Servicing | 17 | 2nd March 2007 12:09 |
| Indicator indicators? | MARK182 | Lights | 2 | 19th January 2007 17:27 |
| Cancelling my Civic!!! | ads | And goodbye | 40 | 29th November 2006 19:19 |
| Rear Indicators | elfa7 | General Discussion | 3 | 25th August 2006 06:33 |
