![]() Join Date: 1st June 2012
Optimum Light Position?
I havent had the car long (2007 type-s GT) but a few times now, oncoming drivers have flashed me even when dipped beams are on. I think its my left light which is a bit too high (i know it should be slightly higher)
I have tried adjusting with the knob on the dash but doesnt seem to make much difference. I know you can adjust them from under the bonnet but just wondering if there was any easy way to get it correct? I dont have a blank wall or anything close by to test them either. They are not xenons, just normal bulbs |
Most Active Australian
![]() Car: 2010 Black Civic Si FK2
Thanks given: 67
Find out where they should be then set up a table cloth infront of the car that is hung up and adjust them using that, no need for a wall.
![]() Car: 2007 CTR GT, NHB
Thanks given: 100
As a local MOT garage to set them up correctly.
Probs not charge you or if they do it won't be much. You will never get them right doing it yourself. |
#4 (permalink) | |
...............Daedalus
![]() Car: CW Type R No. 460
Thanks given: 222
You should be able to set them to 0 (with nothing in the boot) without being flashed by other motorists. Sent from my Sony Xperia S using Tapatalk 2 |
Similar Threads for: Optimum Light Position?
| [HOW TO] Replace headlight bulbs & front position light | jw | How To | 123 | 18th May 2013 16:33 |
| Bulbs Auto position on light stalk | julioarca | Lights | 11 | 21st April 2011 21:42 |
| Extra Position Light | carlskinner | General Discussion | 2 | 3rd November 2010 19:06 |
| Bulbs Struggling to remove position light buld | hoskurner | Lights | 4 | 8th April 2010 18:47 |
| Type R optimum Acceleration | Newbie76 | Type-R | 1 | 11th May 2009 16:37 |
