This thread is about: How to removal standard rear indicators, it's in Lights at the Honda Civic forum Civinfo; Hi everyone I will get Type R rear indicators soon so How to removal standerd rear indicators Is easy to do ? also where i ...
Old 11th September 2007, 21:37   #1 (permalink)
Type S 2.2 i-CTDI GT's Avatar
Hi everyone
I will get Type R rear indicators soon so How to removal standerd rear indicators Is easy to do ? also where i get silver bulb from ?
Many thanks
Alan
Type S 2.2 i-CTDI GT is offline   Reply With Quote
Old 12th September 2007, 00:12   #2 (permalink)
pretty easy
open the boot
do NOT peal away the rubber surround thing - like I did
There is a plastic panel sort of next to the indicator unit, between the unit and the rubber seal.
This needs to come off...
As per typical Honda, it's pressed into place and held by clips.
It feels like it's going to snap into a million peices, but it doesn't
Just be careful and protect the paintwork as you lever it off.
Under that are 2 screw heads.
undo them
wonder what is now holding the unit in...
basically, not a lot - it's a lug into a rubber gromet, at the back of the unit (towards the front of the car).
A gentle backwards thud with your fist (towards the back of the car) and a bit of a wiggle should see it come free
All that is holding it in place now are the wires to the bulb holders
bear in mind that the R unit has / needs bulb holders which have lugs in different places.
See the 'De-tango' thread for pics
you could do as I did (carefully file bits away till the non R holders fit the R units), or do it properly by buying R bulb holders...
Bulbs are silver vision wedge
Silver Vision replacement indicator bulbs - WY21W (Wedge Type) Philips Silver Vision (pair) £15.45 before discount
https://www.autobulbsdirect.co.uk/pr...roductid=16461
Similar Threads for: How to removal standard rear indicators
type r rear indicators pete23 Holdcroft Honda 5 12th September 2007 13:02
Electrics Dashboard Indicators PaulB Bugs, faults and irritations 15 24th April 2007 22:34
Speakers is there a 3 door rear speaker panel removal guide? andy dys Ipods, MP3 Players and ICE 1 27th March 2007 18:56
Indicator indicators? MARK182 Lights 2 19th January 2007 17:27
Rear Indicators elfa7 General Discussion 3 25th August 2006 06:33
