| This thread is about: No wiring to Boot light!!!, it's in Lights at the Honda Civic forum Civinfo; Boot light not working. So pulled it out and found it was not connected. No wiring to be seen!!! The glove box light also doesnt ... | ||
Type S GT
The glove box light also doesnt work, but I dont know how to get that out to have a look. |
Pull down on the white diffuser of the GB light and it should un clip bringing the bulb assembly and loom with it.
Could the boot light wiring fallen down behind the trim, I doubt it's missing all together - mind you it is odd the GB light does not work either |
I had the same problem with my boot light. I could actually feel the cable, but couldn't extract it from behind the trim so got my dealer to do it when I next took it in.
#4 (permalink) | |
Type S GT
Checked in the boot again. No wires to be seen. I cant get my fingers in very far. Looks like the trim needs to come off. A trip to the dealer me thinks |
S29 AWS
Hey Robbo,
I had exactly the same problem in my Type-S. The boot light was fitted... but not connected! So i phoned up the dealer and told them to fix it, they took it for a day and fixed the boot light and did 2 re-calls at the same time. |
Type S GT
See this:
Boot interior trim hanging off Why is this common?? Are Honda technicians poor? Is it the fault of the dealers? Is it not in the instructions for fitting the sensors? Is it our fault for using that dealer? Is it our fault for buying a Honda? When the Service manager admitted that the wire was missed when fitting the sensors and that the split trim was more than likely done by the fitter, he still offered no apology!! |
#8 (permalink) | |
Type S GT
The bulb was faulty. Last edited by robbo51; 30th September 2007 at 18:25. |
Hi, have my car since 26th of october and also 'missed' the boot licht. Until i read about it in this forum. Took al look and there it was. Took it out and found the loom. Connected it and there was light! The car is from february this year (model 2006) and the first owner probably didn't mis it.
most dealers disconnect the boot light on showroom models
to stop the battery going flat when tailgate is up or not closed properly. place the lamp holder back in its location hole, and then forget to connectit up again when the vehicle is sold, happens on most makes of car. |
| [HOW TO] Wiring in a Snooper | Pottsy | How To | 41 | 21st June 2008 17:28 |
| Subwoofer Wiring Views | m4rky | Ipods, MP3 Players and ICE | 0 | 5th September 2007 12:04 |
| Bulbs Blue boot light? | sprkeh | Lights | 4 | 5th June 2007 13:51 |
| Electrics Boot Light | kernowcivic | Electronics | 4 | 3rd May 2007 16:31 |
| Electrics 12V wiring..where? | Jani | Electronics | 6 | 29th November 2006 10:39 |
