Go Back   Civinfo > 8th Generation Euro Honda Civic > Lights
Old 30th October 2012, 18:00   #1 (permalink)
Chilly Sauce + Mayo
Subz_Civic's Avatar
Car: 06, Cosmic Grey Pearl
Thanks given: 10
No interior lights working!
In a bit of a pickle - tried changing my boot light and now non of the interior lights are working! I think I might have blown a fuse or something. I anyone know how I can fix this please
Subz_Civic is offline   Reply With Quote
Old 30th October 2012, 18:15   #2 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 840
Check fuse #17 under the bonnet, that's the interior lights fuse.
There's also #14 in the fuse panel in the driver footwell.
Thank You to Syx from 2 Users:
Old 30th October 2012, 19:30   #3 (permalink)
firstcivic's Avatar
Car: 08 2.2 nhb type s gt
Thanks given: 135
Its the one under the bonnet,u want to go for,did this myself recently looked at the one in the foot well,it was'nt blown,taught i was after doing sum serious damage,never taught there would be two different fuses for interior lights,jus took a chance and looked threw my manual,luckily there was the second one, #17 under the bonnet
firstcivic is offline   Reply With Quote
Old 1st November 2012, 21:06   #4 (permalink)
spako's Avatar
Car: 2006 1.8 5 door, Cosmic grey
Thanks given: 7
I have a similar issue, no interior lights on the dash.
I've checked all fuses (including #14 in the footwell and #17 under the bonnet) and they are OK.
I don't have any glove box bulb at the moment though, can it be causing the problem I'm experiencing?
spako is offline   Reply With Quote
Old 1st November 2012, 22:05   #5 (permalink)
Minas's Avatar
Car: 2009 1.4 100HP 5d Milano Red
Thanks given: 489
Experienced this problem once when I changed my boot light.Turned out it was the fuse #17 under the bonnet if I remember well.
Minas is offline   Reply With Quote
Old 2nd November 2012, 03:22   #6 (permalink)
Most Active Australian
Grayfox's Avatar
Car: 2010 Black Civic Si FK2
Thanks given: 67
Eco display Eco display
Under bonnet fuse #17 and it is a 7.5amp(brown)
Grayfox is offline   Reply With Quote
Old 2nd November 2012, 08:53   #7 (permalink)
...............Daedalus
mpn_daedalus's Avatar
Car: CW Type R No. 460
Thanks given: 222
Apparently it's fuse #17 under the bonnet
Sent from my Sony Xperia S using Tapatalk 2
mpn_daedalus is offline   Reply With Quote
Old 2nd November 2012, 10:01   #8 (permalink)
spako's Avatar
Thanks given: 7
3 posts in a row confirming that it's the fuse #17 under the bonnet when I clearly stated that it's already been checked, lol
Will the interior lights go off if I remove the glove box bulb completely?
I don't have a spare one to try and see if this fixes the problem.
Old 2nd November 2012, 10:09   #9 (permalink)
NoNumpty's Avatar
Car: 2008 2.2 i-CTDi ES NHB
Thanks given: 57
glove box light only comes on when the car lights are on - interior lights come on when you open the door regardless if the car lights are on or off
Old 2nd November 2012, 10:46   #10 (permalink)
spako's Avatar
Thanks given: 7
Then I'm crossed why the interior lights don't come on despite all fuses being OK.
Old 2nd November 2012, 11:02   #11 (permalink)
NoNumpty's Avatar
Thanks given: 57
same with all doors and boot?
Old 2nd November 2012, 11:10   #12 (permalink)
spako's Avatar
Thanks given: 7
No, only the radio/aircon buttons lighting etc. I think the same fuse is responsible for glove box and this is why I thought that if glove box bulb is removed, it breaks the circuit.
Old 2nd November 2012, 11:52   #13 (permalink)
Grayfox's Avatar
Thanks given: 67
You should have a spare as my car came with spares from factory.
In the middle you will see a bunch of fuses that have no connection to anything
And should in this layout
[30][20][15][10][7.5]
These are the spare fuses in their amp rating.
Old 2nd November 2012, 11:55   #14 (permalink)
spako's Avatar
Thanks given: 7
Sorry, let me rephrase it...
I don't have a spare glove box bulb to try and see if this fixes the problem.
Old 2nd November 2012, 12:02   #15 (permalink)
Grayfox's Avatar
Thanks given: 67
Fuse that is boxed is fuse 17 which is 7.5amp
you can see the row of spare fuses and that they have no connection, i have replaced the 10amp as well as my 7.5 one that is why they do not look like the others.
Thanks to Grayfox from:
Old 2nd November 2012, 12:20   #16 (permalink)
spako's Avatar
Thanks given: 7
That's great, but as I mentioned earlier, ALL my fuses are absolutely fine - I've checked each of them using a multimeter.
Old 2nd November 2012, 12:25   #17 (permalink)
NoNumpty's Avatar
Thanks given: 57
is it your dash lights not working rather than the lights that come on when you open the door - fuse 17 is for the interior lights not the dash lights - I would think the dash lights are on the same circuit as the glove box light - do all your outside lights work?
Old 2nd November 2012, 12:39   #18 (permalink)
spako's Avatar
Thanks given: 7
The only lights that are not working are the ones that normally light up the buttons in the centre panel like radio, aircon buttons etc.
The dome lights on the ceiling are fine as are the ones behind the steering wheel (speedo etc). All outside lights work as well.
Please note, I'm currently waiting for the replacement glove box bulb to be delivered, there is no bulb in the holder at the moment.
Which fuse is responsible for glove box light?
Old 2nd November 2012, 12:51   #19 (permalink)
NoNumpty's Avatar
Thanks given: 57
fuse 14 internal fuse box - but all your fuses are fine so it can't be a fuse
Thanks to NoNumpty from:
Old 2nd November 2012, 12:53   #20 (permalink)
Grayfox's Avatar
Thanks given: 67
damaged loom, bad relay.
you need a wiring diagram.
Similar Threads for: No interior lights working!
Interior interior lights not working michael-GT Lights 12 15th February 2013 03:05
Interior HELP !!! Interior Lights Not Working. civicRSA Lights 2 16th January 2011 20:10
Interior Blue Theme: RickR floorwell lights & Mr. JP Interior Lights combined :) iffe Lights 16 17th September 2010 19:06
Interior interior light not working, LED bulbs also not work danlat1415 Lights 5 5th August 2010 20:52
Electrics Interior Lights not working jthynne Electronics 22 21st October 2008 10:01
