| This thread is about: anyone adjusted their headlights up a bit?, it's in Lights at the Honda Civic forum Civinfo; Originally Posted by Skaven252 If I load something very heavy in the trunk the lights should be adjusted back down a bit, right? Correct, I ... | ||
#22 (permalink) | |
Enthusiastic Supporter
Close Encounters with a space ship?
I have a SEAT that lights up but I don’t make the same mistake - maybe it’s the way it lights up like a Christmas tree and mesmerises me? It’s a bit scary! |
#23 (permalink) |
Er... well... I tried. Turns out there's no such knob! Its location is indicated in the manual (immediately left from the steering wheel), but when I look at the console, it's not there.
Has it been located somewhere else? Do I need get into the dash to adjust the lights? |
#24 (permalink) | |
Skaven, Which variant do you have - does it have HID lamps? If so you will need to get under the bonnet and adjust the knob/screws there. You can also do this for those vehicles that have an adjuster in the cabin if you cant get the desired adjustment. I'm sure the fitment/adjustment is similar if not identical Still suggest reading this thread: Think I found the adjusters for the HID Lights. HID or not! Last edited by Miggins; 6th November 2006 at 18:21. |
#26 (permalink) |
unfortunately, for those of us with HIDs, whilst locking the wife in the boot may solve many problems (and probably cause even more...), it won't make the beam any higher, as the HIDs have self adjusters for just this eventuallity
Ok - possibly not this exact eventuality, but they do self adjust for heavy loads in the boot Not that I'm discussing the weight of anyone's wife! |
#28 (permalink) |
I took my Civic to the dealer today to have the creaky rear suspension fixed. I also asked them to adjust the headlights up a little bit. Better let the professionals do it than try tweaking them myself.
Oh, and I also asked them to fix the condensation of moisture in the rear indicators. Seems like a pretty common problem. |
#29 (permalink) | |
Diesel Demon
Damian |
#30 (permalink) | |
#31 (permalink) |
The main and dip beams can be adjusted independantly using a 6mm hex key.
I will try this tonight and report later with results/pictures. |
| How To Set Up The Headlights | IWANTACIVIC | How To | 9 | 26th March 2008 20:57 |
| Automation Automatic headlights | stu_iow | Electronics | 52 | 13th October 2007 08:36 |
| Head ES Headlights | civicg | Lights | 15 | 23rd March 2007 11:19 |
| Options HID headlights | apd | Buying, Dealers and Servicing | 12 | 11th October 2006 04:36 |
| HID HID headlights | karlak | Lights | 11 | 18th June 2006 11:20 |
