| This thread is about: intermittent blue LED cluster problem, it's in Lights at the Honda Civic forum Civinfo; Noticed that my LED cluster in the main interior light was no longer emitting any light. Tried the different switch settings - no differance. Pulled ... | ||
Tried the different switch settings - no differance. Pulled it out and put back the original bulb. Worked a treat. Put the led cluster back and played with it a litte - it was not loose and still did not work. After some playing around it started working intermittently and then - all the time. So now it works... I am guessing there is some intermittent fault in the actual cluster - but it looks impossible to open up. Any one had this? Any one managed to open the cluster? Any one made a warranty claim to autobulbs? |
Went back to intermittent again...
Tried the sand paper method (thanks) today, seem ok now. Will give it a week before I feel comfortable though. |
I have had the problem again.
The wire from the LED,s are bent over the end of the blue plastic under the metal caps this is poor and the problem. How to fix. A little heat from a soldering iron on the cap and pull it off,you will see the wire unbend it and solder a short length of flexible copper wire to it then solder the other end into the cap and push the cap back on . Do both ends result 100% go on give it a try cheers |
| Engine 1st problem | christophe | Bugs, faults and irritations | 9 | 7th April 2007 18:56 |
| Alloys Choice would i have a problem | civic_jaso | Wheels, Tyres, Suspension and Brakes | 1 | 6th March 2007 18:19 |
| Other Spoon Type R or JDM Type R cluster.... | 06Fg2 | Electronics | 15 | 1st March 2007 02:38 |
| Phone HFT problem | davemac | Electronics | 5 | 7th January 2007 10:46 |
| Satisfaction Have you had a problem? | Maldax | Bugs, faults and irritations | 28 | 15th December 2006 22:49 |
