This thread is about: Improving blue LED over gearstick, it's in Lights at the Honda Civic forum Civinfo; There is a small standard blue LED which is between the 2 reading lights. It does not give very much light. I have seen one ...
Old 28th October 2007, 14:34   #1 (permalink)
I have seen one post about drilling up the hole:
[HOW TO] Swap the microphone from left to right
But it does not say anything about drill size or results.
Anyone else tried this and if so, what drill did you use?
Old 28th October 2007, 15:45   #2 (permalink)
Just a basic member
amronno's Avatar
Found this link, I find it a bit interesting, it might give you some answers;
How to change a led
amronno is offline   Reply With Quote
Old 28th October 2007, 16:15   #3 (permalink)
Thanks, had not seen that actually.
But that is changing the LED which is a but further than I want to go. I think that might be too bright.
Old 28th October 2007, 18:03   #4 (permalink)
Jack The Lad.'s Avatar
Pottsy took the light cover off and used a little Dremel drill and bit to increase the hole diameter in the cover.
Did give a bit of extra light, but not much.
Think he would have mentioned, upping the LED, if it was that easy.
Jack The Lad. is online now   Reply With Quote
Old 4th November 2007, 19:52   #5 (permalink)
I followed Pottsy's lead...
if you look at the hole as it is, its 0 shaped.
I simply drilled it out to be O shaped instead - no bigger as such, just rounder
still doesn't give a lot of light, but more than it did before
Similar Threads for: Improving blue LED over gearstick
Type 'R' gearstick - Will it fit??? caz1562 Styling 67 29th June 2008 00:32
Anyone ever made their own GearStick???? CE_CIV_sport07 General Discussion 0 21st October 2007 22:16
New, Blue and Shiny BobM Introduce yourself 14 6th August 2007 22:25
Vivid Another Blue one! MC Hammer Gallery 8 26th August 2006 09:50
Improving Finland's image around the world. Copycat Any non Civic chat here please! 5 14th July 2006 07:42
