This thread is about: LED replacement - problems, it's in Lights at the Honda Civic forum Civinfo; Has anyone had problems with the items not working. Ive put them in an noticed straight away that they are flickering - both of them ...
Old 6th November 2007, 17:34   #1 (permalink)
Ive put them in an noticed straight away that they are flickering - both of them sometimes on sometimes off ...
Ive changed them around - and ive got a long nose tweezer and pressed together the light fitting socket so as to make a tighter hold on the bulbs when in...
https://www.autobulbsdirect.co.uk/product.php?productid=16702&partner=civinfo
MoOriginal is offline   Reply With Quote
Old 6th November 2007, 18:45   #2 (permalink)
Type S GT
Probably faulty. Send the back
Old 6th November 2007, 19:09   #3 (permalink)
Which LEDs are we talking about?
Myself and one more user had issues with the internal "cockpit" LED.
Mine sorted itself (it seems) with some sanding, others needed more work.
intermittent blue LED cluster problem
Old 6th November 2007, 22:24   #4 (permalink)
Im talking about the 1st position sidelight/running lights
Ive read your thread the design of the bulb seems similar in that it has wire bent over to make connection perhaps roughing up the wire will help?
Old 9th November 2007, 19:52   #5 (permalink)
Maybe..
Could be worth a try.
My sidelights are fine.
Old 9th November 2007, 22:41   #6 (permalink)
allan40alt's Avatar
Led lights have to be inserted the correct way round. If the don't work pull them out rotate 180 deg and re-insert.
Old 9th November 2007, 22:44   #7 (permalink)
If they are 180 degrees out they will not work at all.
The problem here was intermittent.
Old 14th November 2007, 08:58   #8 (permalink)
Can you belive it havent had a chance to rough the wires up
really must pull finger out
ive put the original bulbs back in the meantime
before someone comments !
Old 16th November 2007, 20:03   #9 (permalink)
bikefright's Avatar
I don't know for the Civic as I'm new to the scene, but for my Audi, I had to use inline resistors with my LED sidelights. Something to do with the on-board diagnostics (bulb blown warning on the dash) and having the "right" resistance to simulate a true filament bulb. Don't know off the top of my head if the Civic does this......worth checking perhaps?
bikefright is offline   Reply With Quote
Similar Threads for: LED replacement - problems
Bulbs Replacement sidelights Lex Lights 42 7th July 2008 23:00
Speakers replacement car speaker??? ante00 Ipods, MP3 Players and ICE 1 26th April 2007 11:50
Phone HFT Replacement. jimbo Electronics 1 21st March 2007 22:15
My Replacement car is here Topcat General Discussion 4 26th May 2006 21:23
Replacement Car here!! Topcat General Discussion 7 16th May 2006 07:00
