This thread is about: Centre Pocket LED Light., it's in Lights at the Honda Civic forum Civinfo; just remove the 4 screws holding the centre console,this gives access to the cig lighter,2 wires white(live) black (neg) then just remove the gear shift ...
Old 14th November 2007, 17:27   #21 (permalink)
gers's Avatar
just remove the 4 screws holding the centre console,this gives access to the cig lighter,2 wires white(live) black (neg) then just remove the gear shift surrond so you can pass the wire to the centre pocket . I just ran the wire along the hinge of the pocket, its so fine you dont see it as I could not find a way to get at the pocket from the back ,(with out removing glove box) with the lid closed you dont see.No resistors needed and yes the glove box light stays on with the door closed ...Hope this helps
gers is offline   Reply With Quote
Old 14th November 2007, 19:23   #22 (permalink)
Koen's Avatar
Originally Posted by gers View Post
....No resistors needed and yes the glove box light stays on with the door closed ...Hope this helps
No resistors? So you directly connect al LED to 12-14.4 volts? That won't last for long...
I suggest you add a series resistor, depending om the LED type. I guess the value should be between 720 ohms and 1.2k.
K.
Old 14th November 2007, 19:37   #23 (permalink)
gers's Avatar
Hi Koen thanks for that.. I dont know a lot about car electrics but I assumed because its a 12 volt LED that it wouldnt need ,would this be right??
Old 14th November 2007, 20:31   #24 (permalink)
Hi gers, are the 4 screws holding the centre console visible and how is the gear surround removed? I wish there was a haynes manual available!
I suggest you fit a 1kohm resister to your led otherwise it will burn out quickly. They're only like 7p or something from Maplins. That what I use when I make up my own LED's.
Naresh is offline   Reply With Quote
Old 14th November 2007, 22:53   #25 (permalink)
gers's Avatar
Thanks Naresh, I will get one of those from maplins this week, where excatly does it fit, I assume its just in line on the live wire.......... If you slide the 2 front seats right back you will see at each side of the console (1 each side, low down) a small round cover which just pops off using a thin screwdriver to reveal the screws, there are also 2 at the back . The gear surround will prise out again using a thin screwdriver (cover the screwdriver with a cloth as the surround will scratch easily).
Old 15th November 2007, 07:25   #26 (permalink)
Thanks mate, yes the resister just solders onto the positive leg of the LED (longer side), then just cover it up with heat shrink, use a lump of plasticine or blue-tak to hold the led while you solder the resister on, because its a very fiddly job!!
Old 15th November 2007, 07:42   #27 (permalink)
Type S GT
Originally Posted by TTDegs View Post
robbo, shut up you old git
or just fit one and impress your daughter
ok - that probably won't actually work if your daughter is anything like mine
I remember the days when simply fixing the brakes on her bike was enough to impress...
I'll shut up now
nice light
What wrong with being an old git Taffy???
My daughter is a design student and she says its naff too!!
.........Ok off to maplins we go!!!....or is it Butlins!!!??
BTW Resister?....er over the top IMO
Similar Threads for: Centre Pocket LED Light.
Type R light unit centre smoked with red H to fit Type S ? Type S 2.2 i-CTDI GT Holdcroft Honda 12 28th January 2008 17:02
wanted - rear centre light section lazzy git For sale and Wanted 12 15th September 2007 16:35
3G/WiFi Pocket PC for sale (O2 XDA EXEC) basegreen For sale and Wanted 18 21st December 2006 22:16
Brake Centre Brake Light ? belliowalnut Lights 9 27th November 2006 13:59
Options Rear Seatback Pocket Brian Buying, Dealers and Servicing 4 2nd July 2006 23:03
