This thread is about: Think I found the adjusters for the HID Lights, it's in Lights at the Honda Civic forum Civinfo; Originally Posted by Deemon Miggins, The adjustment is not made via the rubber knobs but by an Allan Key type screw further back and down ...
Old 6th November 2006, 18:17   #21 (permalink)
Enthusiastic Supporter
Miggins's Avatar
Rubber Knobs
Originally Posted by Deemon View Post
Miggins, The adjustment is not made via the rubber knobs but by an Allan Key type screw further back and down into the engine compartment a few inches further in than the rubber thing. It was a white plastic screw head it I remember correctly, have a look just behind the rubber bits and you should see it.....I will post up a pic when I get a mo..
Hello Deemon,
Sorry - only just picked up on your post. I think I know which adjusters you mean. Do you know what the rubber knobs are for? I'm sure they made some difference but not enough!
Old 9th November 2006, 00:28   #22 (permalink)
Diesel Demon
damianscott71's Avatar
Miggins,
Did the adjusters work? I need to do mine before I drive into a tree, or worse, 2 trees.
Damian
Old 9th November 2006, 11:47   #23 (permalink)
Miggins's Avatar
Homer, Homer Simpson, he's about to hit a chesnut tree. . . . argghh!!!
They did but there was very little improvement as the lights were so close to the max height already. Still not sure what purpose the rubber knobs serve - poss just a fine adjustment.
Need to have a look at the keyed adjusters. I haven't needed to tweek these on other vehicles . . . mmmm!!!!!
Old 9th November 2006, 15:12   #24 (permalink)
Miggins's Avatar
The true adjusters?
OK just examined the adjusters mentioned by Deemon (thanks Deemon )
It appears the main and dip beams can be adjusted independantly using a 6mm hex key.
I will try this tonight and report later with results/pictures (After resetting the rubber headed screws back to what they were).
UPDATE:
Adjusted the white hex head that sits directly behind the dipped beam and up the beam came. One full turn clockwise with a 6mm hex key and the beam went from useless to approx what I believe is safe and legal (mmm!)
I didn't go to flat and level ground to adjust as I was only incresing the height (lateral setting is ok) and wound each side up the same measured amount (easy to put back if wrong). Photos dont show anything as its hard to see a difference when the wall/garage is only 6ft away!
After winding the adjuster in half a turn clockwise and a test drive, I realised another half turn was required - now dipped beam is lighting up the rear bumper of other vehicles from abot 30ft ~ 10m away. I believe the static setting is now correct but 'enthusiastic' accelerating results in possible dazzling of oncoming drivers. Need to assess this on a longer drive.
Picture of the adjuster later when my other half gives ME, MY car back - she seems to like it!!
I'm a lot happier and safer!
Old 11th November 2006, 20:10   #25 (permalink)
Diesel Demon
Just done mine 3/4 turn clockwise, don't want to dazzle people with my constant enthusiastic acceleration!
Damian
Old 13th November 2006, 23:15   #26 (permalink)
Maldax's Avatar
Just given mine a tweak! So much better!
Old 19th November 2006, 02:11   #27 (permalink)
joora's Avatar
Can anybody put a picture of the adjusters?
joora is offline   Reply With Quote
Old 19th November 2006, 03:03   #28 (permalink)
Miggins's Avatar
Smile
Pic as requested - unfortunately by battery died and with no flash the camera would focus!
The vertical adjuster sits directly behind the outer/dip lamp. Circular/white with a 6mm hex head. The other adjuster (probably for lateral adjustment) sits behind the main beam. Both are facing upwards.
Better pic tomorrow in the warm sunshine (mmm!)
Old 19th November 2006, 03:13   #29 (permalink)
IWANTACIVIC's Avatar
at miggins , there might be sunlight tommow but not a lot of warmth i bet if its like today . yer i got used these same looking adjusters to setup my last car 1 job i got to do on the civic.
Old 18th August 2007, 08:34   #30 (permalink)
On my car there is very clear labeling of these on the black plastic which covers the lights etc under the bonnet. The inner ones are marked L-R and outer ones Up-Down.
Similar Threads for: Think I found the adjusters for the HID Lights
Found a card under your wiper? Pottsy Was it you? 36 26th June 2008 02:28
Found This Classified Ad beepee Any non Civic chat here please! 10 15th April 2007 09:23
Satnav List of errors found with sat nav - old vs new TTDegs Electronics 16 5th March 2007 20:47
Oooohhh look what i found!! Andrea Site suggestions, feedback and rules 20 17th December 2006 21:02
finally found an 06 forum :) daiashthomas Introduce yourself 8 16th October 2006 08:01
