#623 (permalink) |
![]() Car: 2007 CTR
Thanks given: 36
I will forge my engine for next season! I will not blow more than 14/15 PSI or more than 450BHP
BTW first mod! Bored TB 70mm. Now my TL TB will fit perfectly!!! ![]()
#628 (permalink) |
![]() Car: 2007 CTR
Thanks given: 36
Guys i need advice!!!
I decided to forge my engine and i need 10:5:0 standard bore pistons!!!! Who can tell me where i can buy these pistons because i looked around and found only 9:8 and 11:5 or higher... What is going on?????? |
#632 (permalink) |
![]() Join Date: 25th September 2009
Thanks given: 88
Mahle 10.5: ACR176386F03 86mm
Import Performance Parts - Acura Mahle Pistons MAHLE PISTONS ACURA RSX K20 / K24 86.50b 86s 139r 12cc | eBay Why not just get some shelf 11.0 wisecos, or CP's. You putting these in a new engine or your current engine? |
#633 (permalink) | |
![]() Join Date: 2nd October 2007
Thanks given: 8
Good find on the Mahles.... not custom, but very good (Low) expansion rate!! |
#634 (permalink) |
Thanks given: 8
Hey Marcin,
I realised that I tried ti answer your question without even thinking about your st-up. JE Custom Piston rule, and I tried to show you that, but, when I got home and looked at i twith more time..... a questions came up: - Why only 10.5 CR?? You are running a ROTREX, not a Turbo, and even a Turbo with our 98 RON doent need the CR thats most people say. Rotrex likes a bit of Compression, you can easily run 11.5 / 11.7 CR! Think about it.. |
#635 (permalink) | |
![]() Join Date: 7th April 2012
the 4th already He advised me 9:5 He said if you flattens the head you gonna end up almost 10 compression He advised me not to go higher so that the engine would last longer the risk of detonation is too big Hey Marcin, What did you decide to go for 10: 5? |
#636 (permalink) |
![]() Car: 2007 CTR
Thanks given: 36
BERTJE
few people advice that i need 10:5 for best performance but i must change my plans! I thought about install these pistons and rods without remowing engine. Few people told me today that i MUST bore to fit perfect new pistons!!!! I have on block BBBB pistons so i thought it will be straight and easy install!!! Right now consider install stronger rods with OEM pistons but i is this good IDEA?????? Last edited by mw1978; 4th October 2012 at 18:40. |
#637 (permalink) |
![]() Car: 2007 FN2 GT
Thanks given: 159
I don't think a rebore is necessary to fit new rods, especially if the hone is 100%. I have heard of a re-hone sometimes to tidy it up if thats not perfect but not a re-bore. Why do they sell stock sized pistons then.
#638 (permalink) | |
I go to my tuner with this proposal I've already gotten prices of + 4000 euro for the engine only without the price for out and back insert of the engine expensive hobby
#639 (permalink) | |
![]() Join Date: 26th May 2008
Thanks given: 72
You don't need to bore. If you want to make it more perfect just hone it. But even honda don't say that you need to hone, only if the Sleeves have scratchs. On stock sleevs the only pistons i would use are oem or mahle. |
Thanks to nunoctr from:
#640 (permalink) |
![]() Car: 2007 CTR
Thanks given: 36
Thanks NUNO for advice!!!!
BTW i have never heard about MAHLE!!! Whey You recommend these pistons????? Last edited by mw1978; 5th October 2012 at 20:31. |
Similar Threads for: My red devil
| God, the devil & fat | NoNumpty | Any non Civic chat here please! | 0 | 9th March 2009 10:29 |
| The evils of "DEVIL" drink | Charles_Harding | Any non Civic chat here please! | 3 | 10th July 2007 15:46 |
| My black devil | christophe | Introduce yourself | 9 | 10th April 2007 21:50 |
| Devil's advocate - Anything else worth considering? | simbloke | General Discussion | 8 | 8th November 2006 22:43 |
