This thread is about: Eps Light On,speedo Going Crazy, it's in Previous Civics at the Honda Civic forum Civinfo; Hi I have a 02 civic type r, when driving this morning the eps light came on and the speedo and rev counter needle started ...
Go Back   Civinfo > Honda Civic > Previous Civics
Old 1st January 2008, 17:12   #1 (permalink)
Hi
needle started flickering up and down
plus the power steering goes hard now and again,
can anyone help??
ghani is offline   Reply With Quote
Old 1st January 2008, 17:15   #2 (permalink)
Hi ghani, This forum is for the 8th generation Civic. Perhaps someone can help with your problem, but it doesn't sound too good does it.
Old 1st January 2008, 17:22   #3 (permalink)
No its not good, just thought id get a idea of wot it is as its same running gear as the the new model
be for i take it to dealers
Old 1st January 2008, 17:48   #4 (permalink)
Odds are it's a loose earth (or similar) - but it will need the dealer to look at it.
Old 1st January 2008, 18:44   #5 (permalink)
Originally Posted by ghani View Post
Hi
can anyone help??
Definitely an electrical problem - look under the bonnet for rodent bites on the cables (no joke!) and if there are none, it means a trip to the dealer I guess
Old 1st January 2008, 19:40   #6 (permalink)
S29 AWS
sambuca2907's Avatar
How many miles do you have on the Type-R?
Old 1st January 2008, 20:14   #7 (permalink)
Its done 50000 miles
Old 2nd January 2008, 11:42   #8 (permalink)
hajer's Avatar
Its a alternator fault.
hajer is offline   Reply With Quote
Old 3rd January 2008, 20:56   #9 (permalink)
Civic Fan's Avatar
Both civcs at work had the steering racks replaced under warranty. Not sure of the cause but it sounds similar. Both cars have covered less mileage than yours and are on a 53 plate. Maybe down to abuse or bad driving as these are both company cars with many different unsympathetic drivers. Does seem odd that both should go at roughly the same time and mileage with same type of fault.
Am I mistaken or is the rack on this last generation electric/hydrulic power steering.
Civic Fan is offline   Reply With Quote
Old 3rd January 2008, 21:49   #10 (permalink)
yes but isnt the rack a common fault?
Old 3rd January 2008, 22:06   #11 (permalink)
britsbest's Avatar
Ghani you been to the stealer yet?
Old 3rd January 2008, 22:56   #12 (permalink)
Civic Fan's Avatar
Seems so. get the problem checked out asap.
Old 7th January 2008, 20:44   #13 (permalink)
Hi Britsbest
wots stealer?
Old 7th January 2008, 20:52   #14 (permalink)
Hi Britsbest
wots stealer?
Civinfo-speak for dealer.
As in - they steal your money.
Old 7th January 2008, 21:43   #15 (permalink)
britsbest's Avatar
Hi Britsbest
wots stealer?
One who takes your money and does nothing...........a bit like a dealer
Old 7th January 2008, 21:47   #16 (permalink)
Doesn't even care to run away afterwards
Old 7th January 2008, 21:49   #17 (permalink)
no its goin in 2morrow, and il make sure i get my moneys worth otherwise its goin
back and i wont pay
Old 8th January 2008, 18:49   #18 (permalink)
well guys it went in today and they did a diagnostic check
and reset all the fault codes, and fingers cross it seems ok
Old 12th January 2008, 07:03   #19 (permalink)
longpig's Avatar
Stealer!
The price of the ink on your service book must be far and away the most expensive commodity on the planet weight for weight!
Just a thought
longpig is offline   Reply With Quote
Similar Threads for: Eps Light On,speedo Going Crazy
Calibrate the speedo Pottsy How To 25 12th July 2008 10:49
Satnav My SatNav has gone crazy pjelsworth Electronics 17 21st October 2006 04:31
Speedo speedo briang Electronics 1 9th September 2006 19:27
I will get crazy mrcanadian General Discussion 1 2nd September 2006 11:56
Speedo Speedo Charles_Harding Electronics 9 24th August 2006 23:08
