This thread is about: Steering Problems! Can anyone help?, it's in Previous Civics at the Honda Civic forum Civinfo; Hi everyone! Need some help and advice!! For some unknown reason my Honda Civic (2002) has developed some sort of steering malfunction. Everytime i hit ...
Go Back   Civinfo > Honda Civic > Previous Civics
Old 27th March 2008, 08:44   #1 (permalink)
Hi everyone!
Need some help and advice!! For some unknown reason my Honda Civic (2002) has developed some sort of steering malfunction. Everytime i hit a pot hole or bump in the road my steering wheel pulls into the uneven surface. At times it feels like your fighting to keep it straight! Any suggestions/help would be really appreciated!
honda 123 is offline   Reply With Quote
Old 27th March 2008, 09:57   #2 (permalink)
dragonglance's Avatar
To a degree the wheel will naturally pull into a hole but if it is too excessive i would get it looked at mate
dragonglance is offline   Reply With Quote
Old 27th March 2008, 10:08   #3 (permalink)
yeah it's quite excessive at times. I've had the wheels aligned and that hasn't helped at all!
Old 27th March 2008, 10:50   #4 (permalink)
R-2
R-10581
R-2's Avatar
My old EP3 used to tramline quite badly on rough roads. Feels like you are being pulled into all the uneven bits.
But isn't this a feature if you have wide tyres?
It also had lots of torque steer which made it feel like it was pulling you towards where you didn't want to go sometimes!!
Old 27th March 2008, 10:55   #5 (permalink)
HappyMan's Avatar
Tyres?
Old 27th March 2008, 13:36   #6 (permalink)
Originally Posted by honda 123 View Post
Hi everyone!
If you have fitted wider tyres than the previous ones it's rather normal, otherwise - maybe the shocks are run down and need replacement?
Old 27th March 2008, 15:31   #7 (permalink)
the car has had modified wheels added, which are quite wide! So it looks like this could be the problem! Thanks for your help!!
Old 4th April 2008, 14:18   #8 (permalink)
Diesel Demon
damianscott71's Avatar
If you have tyres with reinforced sidewalls on your wheels, changing them for a different tyre (without) will probably solve the problem.
My 18" alloys felt really bad until I ditched the Yokohamas for Vredstein Ultracs.
Similar Threads for: Steering Problems! Can anyone help?
Steering goes light....... jamesaberdeen73 Type-R 2 16th March 2008 20:39
Steering steering problem Silver Fox Bugs, faults and irritations 1 3rd January 2008 13:01
Steering Steering almost sorted PhilCarrie Bugs, faults and irritations 1 17th February 2007 01:56
Steering tighter? PhilCarrie General Discussion 6 18th January 2007 15:12
