This thread is about: rev/turbo problem (merged), it's in Previous Civics at the Honda Civic forum Civinfo; HEY I HAVE A 1.7CDTI CIVIC (04) DRIVES PERFECTLY BUT AFTER HAVING MY FOOT DOWN FOR A BIT THE TURBO TUNS OFF AND I CANT ...
Go Back   Civinfo > Honda Civic > Previous Civics
Old 17th May 2008, 19:22   #1 (permalink)
Exclamation rev/turbo problem (merged)
HEY I HAVE A 1.7CDTI CIVIC (04) DRIVES PERFECTLY BUT AFTER HAVING MY FOOT DOWN FOR A BIT THE TURBO TUNS OFF AND I CANT REV PAST ABOUT 2,600rpm SUM1 HELP ,ME PLZ!!!
kh52ram is offline   Reply With Quote
Old 17th May 2008, 19:27   #2 (permalink)
Welcome kh,
This forum is for the 06-> Civic, but you may be lucky and find someone who has had one of these in the past or recognises this as a generic problem.
I donīt know if these engines had a "limp home mode", if they do it could be that the engine developes some kind of faults and moves into this mode, limiting the revs.
Old 17th May 2008, 19:28   #3 (permalink)
rev/turbo problem
help! having a little trouble with my 1.7cdti civic (04). drives fine but after a while the turbo stops and it wont let me rev over 2.600 rpm! help plz as my car isnt enjoyabl without the turbo in use
Old 17th May 2008, 20:06   #4 (permalink)
smurf79's Avatar
Best bet is take it to a garage cos it sounds like you've got either a blown turbo or a damaged turbo inlet and the ECU is putting the car into limp home mode due to the MAP sensor giving a false reading
Old 17th May 2008, 20:19   #5 (permalink)
will it be costly?? only 18 n just getin on ma own 2 feet!! hehe
Old 17th May 2008, 20:22   #6 (permalink)
IF it is a blown turbo, then yes, but it could be much less dramatic.
Similar Threads for: rev/turbo problem (merged)
Induction Turbo sound? Civic ASM Engines and Transmission 8 22nd April 2008 12:11
Turbo Acura Integra GSR and Turbo Acura T trev0006 Any non Civic chat here please! 0 26th October 2007 10:39
Performance Turbo for a 1.8 Egbert Engines and Transmission 8 18th August 2007 10:26
Tyre Other Rear tyre problem Civic 1.8 i-vtec sport (merged) cassie Wheels, Tyres, Suspension and Brakes 13 19th May 2007 08:58
Tech turbo timer Type S Bournemouth Engines and Transmission 2 16th February 2007 22:02
