This thread is about: revs dropping???, it's in Previous Civics at the Honda Civic forum Civinfo; Hya I have just brought an L reg civic and have noticed that when I have anything other than the engine on, ie the lights ...
Go Back   Civinfo > Honda Civic > Previous Civics
Old 26th May 2008, 21:13   #1 (permalink)
revs dropping???
Hya I have just brought an L reg civic and have noticed that when I have anything other than the engine on, ie the lights or the wipers my revs drop til the car almost cuts out, it never does cut out but its a pain in the backside! Is this a common problem and does anyone know how to fix it
cheers viki
viki is offline   Reply With Quote
Old 26th May 2008, 21:20   #2 (permalink)
ViBe's Avatar
hmm.. i've experienced this too, but i dont think its anything to worry about. The ECU controls the revs according to the circumstances, for example they are higher when the engine is cold, and then gradually go down as the engine warms up.
ViBe is offline   Reply With Quote
Old 26th May 2008, 21:22   #3 (permalink)
Hi Viki,
This forum is for the 2006+ Civic, but you may find someone who will recognise this problem anyway.
Which Civic is it exactly?
Old 26th May 2008, 22:14   #4 (permalink)
When you turn on anything electric it puts load on the electrical system so the alternator works harder. This puts an extra load on the engine soeducing the revs slightly. It could be that on your car the tickover is set a bit slow. Raising the tickover may help.
Old 27th May 2008, 14:21   #5 (permalink)
Bungle's Avatar
Does the idle speed recover after lights are on, or does the RPM stay too low?
It could indicate a problem with the alternator, but that would also mean your batt runs flat from time to time.
If it stats causing a problem, like the enigine actually cutting out, take it to a garage.
Similar Threads for: revs dropping???
Run in Revs Steeph Engines and Transmission 7 4th November 2007 21:37
Faults revs 500rpm DUNCAN Engines and Transmission 3 22nd January 2007 20:16
Faults iVTEC Idle Revs Meino Engines and Transmission 6 5th January 2007 09:48
Faults CDTI Idle Revs TheRef Engines and Transmission 15 25th October 2006 17:29
Faults Smell at high revs Nick Engines and Transmission 4 20th July 2006 07:14
