Go Back   Civinfo > Other Hondas > Previous Civics
Old 22nd December 2008, 21:40   #1 (permalink)
Civic 98 acceleration problem
hi. im not sure where i should post this but i hope someone can help me. ive got a civic 1.5 vtece 1997 and for the last few months ive noticed a probelm with the acceleration. when i start off in first accelerating normaly then change to second and if i put my foot down it will accelerate up to about 3000rpm then it will fall down to about 2700rpm then start accelerating again. ive also noticed i get the problem when i change down, like if i was in 4th gear coing to a roundabout and changeing to 3rd then if i put my foot down the same thing will happen. it all seems to be happening around 2200 rpm and 3000rpm but sometimes if im in 3rd gear it will happen from 3000rpm onwards. it seems to accelerate ok if i do it normal. there doesnt seem to be anything else wrong with the car, doesnt burn oil etc. ive also checked the oil level and its fine. anyone got any ideas whats wrong and how much it would cost to fix??
aj1soad is offline   Reply With Quote
Old 22nd December 2008, 21:42   #2 (permalink)
The Bulbs Man!
Mr JP's Avatar
Sounds like clutch slip?
New clutch might be in order.
Old 22nd December 2008, 23:28   #3 (permalink)
is that an expensive job??
Similar Threads for: Civic 98 acceleration problem
Engine Acceleration Problem Help jeannie Bugs, faults and irritations 42 20th October 2008 13:55
Lag on acceleration uncler Type-R 31 9th September 2008 10:20
Run in CTS Stuttering and Acceleration Problems j_auluck Engines and Transmission 9 22nd February 2008 15:38
Squeaks Dash rattle under acceleration St3ph3n Bugs, faults and irritations 62 24th November 2007 22:27
Performance Acceleration of a civic 1.4 Doody2008 Engines and Transmission 16 19th September 2006 13:57
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
