#22 (permalink) |
Cockup Specialist
Thanks given: 737
Gotchya, thanks Paul.
Do you seal/arrange the pulse traps to generate a vacuum on the positive pulse and suck out (buffer) the return pulse with the vacuum generated ? [I know there is lots of ways of doing pulse traps and many are designed to just flow better in one way than another (eg a simple step) rather than use a vacuum. I think of one as passive and one as dynamic] Perhaps you could combine SRI + pulse trapped airbox + ramair Have you toyed with using a ramair system for exhaust extraction ? I know overlap is an issue so perhaps this will boost the low and midrange power...especially at speed..perhaps with wilder cams ? Like we pulse tune using exhaust from one cylinder to extract the other...use ramair instead to extract the whole exhaust. Do it right and you could use the high drag areas on the rear with high pressure zones on the front for a much better effect. Last edited by Relic; 8th April 2012 at 15:00. |
#23 (permalink) |
Commercial user
![]() Join Date: 3rd May 2008
Thanks given: 131
That's a very interesting idea with the exhaust but we also have a big challenge of trying to keep the noise to acceptable levels.
Lots of scope for development though and something I think Mark and Sam were exploring on the Lotuss Was funny playing with the intake as we had a big plastic bottle and we were chopping it about trying to find a volume that worked best. Also played with 2 ports connected to the reservoir. Real 'Blue Peter' testing! Andy - yeah as long as we can get good clean air feed. Last edited by tdi-north; 8th April 2012 at 15:36. |
#24 (permalink) | |
Cockup Specialist
Thanks given: 737
#26 (permalink) | |
Go Hard or Go Home!
![]() Car: 2008 FN2 GT
Thanks given: 152
Custom 3.5 inch intake - 8th Generation Honda Civic Forum Check out post number 52 on page 3 for the finished install Last edited by civi08; 8th April 2012 at 16:51. |
#28 (permalink) |
Go Hard or Go Home!
Thanks given: 152
We'd really be looking at something as already suggested mate, filter in a location where cold air can go directly thru fog inserts and be sucked in. I wouldnt want to be paying for carbon/kevlar either, that bumps up cost big time and neither tdi or cpl would be able to create it. Simple 3.5" pipe with a cone filter will suffice.
#30 (permalink) |
Go Hard or Go Home!
Thanks given: 152
Is yours a custom build marcin? Looks like the one in my link above, very smooth weld-less looking 3.5" pipe
#32 (permalink) |
![]() Car: 2007 CTR
Thanks given: 36
this is my work LOL. 100% custom. I bought pipes on UK ebay and pouder coated to match with blower.
Its very hard to fitt that pipes behind front lamp so decided to use two pipes with difrent angle and silicon conector. Cone filter is very big and has velocity stack. On the last picture You can see what i have to protect my cone filter against water... ![]() ![]() ![]() ![]() ![]()
Thanks to mw1978 from:
#34 (permalink) | |
![]() Car: 2008 millano red type r
Thanks given: 36
#35 (permalink) |
![]() Car: 2007 CTR
Thanks given: 36
i have seen that pics many times when i thought about my intake. That pipe is too long and in my opinion intake pipe in one pice is impossible to fit in FN2
Even If you fit that one pice pipe think how You change bulps in lamp??? Last edited by mw1978; 8th April 2012 at 21:19. |
#36 (permalink) |
Go Hard or Go Home!
Thanks given: 152
Yes i know, that isnt a kit that you can buy. Its an example of something we could recreate over here but that DOES fit the fn2. Its the basic design i like and would work good aswel as look clean in the engine bay.
#37 (permalink) |
![]() Car: 2007 FN2 GT
Thanks given: 159
Marcin thats fabulous work mate
Steve, I'll have a chat tomorrow about an idea I have that might help you Marcin If you don't mind me asking where did you source your velocity stack and filter, any part numbers, pipe angles and lengths etc would be appreciated too pal Stephen Last edited by stoney; 8th April 2012 at 21:45. |
#38 (permalink) |
Cockup Specialist
Thanks given: 737
What size pipe, stak and filter is that marcin ?
Thats almost exactly what I need on the derv. Has to be 72mm ID on the tubing for the MAF sensor though. Quote:
Similar Threads for: CAI Fabrication
| TDi North Custom 3" Exhaust fabrication | tdi-north | TDi North | 10 | 15th February 2012 19:28 |
