| This thread is about: Rev limiter = a valuable thing!, it's in Type-R at the Honda Civic forum Civinfo; Originally Posted by Jack The Lad. You are talking about the diesel Ed. ??? probably both but definitely petrol as evilowl is off the CTR ... | ||
#22 (permalink) |
Talking about the R, but I imagine it's the same all round.
Also read somewhere that with a modded ECU and raised rev limit (say 8,800), its safer to go to 8,700 than hit the limiter at 8,400. |
#23 (permalink) |
fortuately the rev limiter as controlled by the ecu will cut the fuel & ignition but unfortuately it wont stop the engine from physically overevving or spinning faster than the redline ,the boffins at honda are aware of this & midway through production of the last civic type r they introduced an extra bit of software in the ecu that records a fault code if the engine has physically spun much faster than the redline.this results in valuable evidence when a warranty claims for a blown engines are submitted.The fault code tells them the engine has been overevved & because of this honda will not be paying for a replacement,so bear this in mind if you regularly bounce your engine on the rev limiter because it could end up being rather costly.
engine damage caused by an engine exceeding its maximum design limit is not a warrantable item. DTC 119-1 |
#25 (permalink) |
This spyware in the car concerns me a little. It's your car, I wonder if it is actually legal to access that information without your permission ?
What a pity they didn't put the effort into making the rev limiter do what it is supposed to do, protect the engine. Last edited by pcr; 11th April 2008 at 23:27. |
#27 (permalink) | |
#28 (permalink) |
Does this apply to you ? I most definitely do not race the engine, 3500 rpm max normally. I did once however, get curious about the rev limiter and put my foot down in 2nd gear. So is it likely that this one activation of the rev limiter has voided the engine warranty, let's hope not.
Also, the rev limiter appears to be undocumented. |
#29 (permalink) |
just to clear the confusion that seems to be developing on this thread,hitting the rev limiter occasionally wont destroy your engine,the rev limiter will safeguard this ,what it the rev limiter wont do is phyisically stop the engine spinning past its maximum design speed ,which when this occurs a fault code will be stored in the ecu detailing the overspeed.which in the event of an engine failure will void any warranty claim
#32 (permalink) |
pcr - hondatech is really referring to abuse. Say you were on a track day, and selected the wrong gear in the heat of the moment (say 2nd instead of 4th) and the revs went briefly to 9500, and something in the engine broke. The high revs DTC will record this, and you will not be able to rely on Honda to pay for the driving error - naturally you'd have to pay for it yourself.
#35 (permalink) |
Borrowed from CTRO and Hondata:
Hondata wrote:The JDM K20A has a 8600 rpm limiter, whilst the US K20A2 with the same internal parts has a 8100 rpm limiter, so we are comfortable increasing the rev limiter to 8600 or 8800 rpm. One important point is that hitting the rev limit places a lot of stress on the engine, no matter where the limiter is. It is better to rev to 8500 rpm than hit the limiter at 8100 rpm. Also do not hold the engine on the rev limiter if you miss a gear - I've seen more than one engine expire this way. Another factor with the rev limiter is that the early K20A & K20A2 engines had weaker dual intake valve springs. Honda upgraded these some time in 2002 to a single valve spring (supposedly from the S2000). Owners of the earlier engines should consider changing the valve springs if they race the car. You'll lose a little power doing this. Connecting rods are a point of debate at the moment. We know they can fail at 9500 rpm, so setting the rev limit below 9000 rpm seems like a good idea. |
#38 (permalink) |
Moved on
It also records the speed you were doing at the time if you over rev it. Which makes you wonder if it would record this data in the event of an accident?
#39 (permalink) | |
| Performance Rev Limiter | dragonglance | Engines and Transmission | 15 | 25th March 2008 20:15 |
| Nissan GT-R recognizes tracks via GPS and removes speed limiter | trev0006 | Any non Civic chat here please! | 3 | 23rd December 2007 21:04 |
| the size of the thing | panasony | General Discussion | 13 | 30th January 2007 11:45 |
| Long list Have I done the right thing? | Bart | Bugs, faults and irritations | 14 | 12th September 2006 01:07 |
| Windows window thing lol | Andrea | Bugs, faults and irritations | 10 | 29th August 2006 09:47 |
