This thread is about: Rev limiter = a valuable thing!, it's in Type-R at the Honda Civic forum Civinfo; Just wanted to express my joy at having a rev limiter - I'm sure my engine would now be a melted pile of metal (or ...
Old 10th April 2008, 09:06   #1 (permalink)
uncler's Avatar
Just wanted to express my joy at having a rev limiter - I'm sure my engine would now be a melted pile of metal (or at least in a bad way) if one wasn't fitted to the Civic! The engine just spins up so quick once you go into lift that often barely have time to change gear, and there the needle is bouncing about at 8000 rpm... Anyone else ever have their engines at these heady heights?
Which leads me onto another question - how many years have cars been fitted with rev limiters? Never really red-lined any of my older cars, so wasn't sure!
uncler is offline   Reply With Quote
Old 10th April 2008, 09:18   #2 (permalink)
cp794's Avatar
They are great aren't they, although a little unnerving when it hits the wall, I have bounced mine off the limiter all through the gear box, trying to keep ahead of a mate on the autobahn in an ST Focus.
cp794 is offline   Reply With Quote
Old 10th April 2008, 09:19   #3 (permalink)
And did you
Old 10th April 2008, 09:24   #4 (permalink)
KE_DK's Avatar
Yes, it's a great thing, and quite necessary.
Rev. limiters have been around for many years, earlier in a mechanical form (based on centrifugal ignition cut-off)
KE_DK is offline   Reply With Quote
Old 10th April 2008, 09:48   #5 (permalink)
Wyrd's Avatar
Bounced mine off the limiter mid-overtake the other day ...it scared the hell out of me! Then quick up-shift and straight into more VTEC!!
Wyrd is offline   Reply With Quote
Old 10th April 2008, 09:48   #6 (permalink)
Comedian/Smart A*se
Yes, it's a sprung part of the rotor arm isn't it on the old centrifugal system (??), much the same as the the old govenor's on steam engines so, you could say they've been around longer than the I-C-E
Old 10th April 2008, 11:03   #7 (permalink)
Newton Honda
NH Dan's Avatar
Nice to know that you are running your car in nice and gently then......lol
Old 10th April 2008, 11:20   #8 (permalink)
Jack The Lad.'s Avatar
So, does my Type S 2.2 diesel have one too.
Never taken it that much into the red.
What happens then,- does the engine die on you, in the middle of overtaking. ?
Old 10th April 2008, 11:54   #9 (permalink)
Comedian/Smart A*se
No you get a slight 'Jerk' and you know to change gear, basically the ECU senses the redline and cuts all fuel and throttle control until it reverts to being under the redline. Can take you un awares, mine does it often
Old 10th April 2008, 12:08   #10 (permalink)
Greedy's Avatar
if you get to the limiter in th 2.2 it has virtually died on you already i don't go much past 3500 - no point.
Old 10th April 2008, 12:32   #11 (permalink)
Why Do I bother?
angie4m's Avatar
I like to make sure the rev limiter is working on a regular basis
Old 10th April 2008, 12:39   #12 (permalink)
Duecut's Avatar
All fuel injected engines have rev limiters, even the very first ones (unless you tamper with the electronics, yup you guessed it I did once and blew the engine ).
Duecut is offline   Reply With Quote
Old 10th April 2008, 14:54   #13 (permalink)
cp794's Avatar
Originally Posted by Jeroen1000 View Post
And did you
It was a bit difficult on the autobahn, but once we got onto the back roads he couldn't even stay close, the front end of the ST is just too heavy!!
Old 10th April 2008, 15:24   #14 (permalink)
Sounds about right; I found a few test suggestings the ST is a little faster from 0 to 60 mph, but then again it has more hp. Revving is much more fun
Old 10th April 2008, 15:28   #15 (permalink)
Nobody gets out alive
NEEMSTAR's Avatar
you need to perfect the art of changing at 7999 rpm
NEEMSTAR is online now   Reply With Quote
Old 10th April 2008, 16:44   #16 (permalink)
hlxbravo's Avatar
2nd gear is usually the one that gets me "bouncing" off it.
hlxbravo is offline   Reply With Quote
Old 10th April 2008, 22:55   #17 (permalink)
R-2
R-10581
R-2's Avatar
When you drive a car that loves to be revved and sounds so good hitting the rev limiter is inevitable occasionally (well alot actually )
Still gives me a shock everytime though
Old 11th April 2008, 18:38   #18 (permalink)
I've touched my limiter twice in 10 months. I think it kicks in at 8,400 or 8,250. I still always change at 8K on the dot, usually by ear. I did read somewhere that hitting the limiter is not a good idea. I'll see if I can find the info and get back to you.
Ed Case is offline   Reply With Quote
Old 11th April 2008, 19:31   #19 (permalink)
Here you go, courtesy of evilowl from CTRO:
Basically when you hit the limiter it puts a lot of strain on the engine and drivetrain. If you brush it now and again it won't cause any harm but over time, if you are hitting it a lot, the timing chain will be stretched and can even jump teeth which will eventually wreck the engine if not checked and adjusted.
Old 11th April 2008, 19:44   #20 (permalink)
You are talking about the diesel Ed. ???
Similar Threads for: Rev limiter = a valuable thing!
Performance Rev Limiter dragonglance Engines and Transmission 15 25th March 2008 20:15
Nissan GT-R recognizes tracks via GPS and removes speed limiter trev0006 Any non Civic chat here please! 3 23rd December 2007 21:04
the size of the thing panasony General Discussion 13 30th January 2007 11:45
Long list Have I done the right thing? Bart Bugs, faults and irritations 14 12th September 2006 01:07
Windows window thing lol Andrea Bugs, faults and irritations 10 29th August 2006 09:47
