| This thread is about: Decat, results?, it's in Type-R at the Honda Civic forum Civinfo; Hi, im hearing things on other forums that there have been mixed results from fitting a decat. Some with gains some with power loss at ... | ||
Decat, results?
Hi, im hearing things on other forums that there have been mixed results from fitting a decat. Some with gains some with power loss at peak/high revs.
Anyone else fitted the mod? |
yeah hes had good results, ive heard of one other whos had bad results due to the pipe getting smaller as it links to the centre pipe.
#4 (permalink) | |
Nobody gets out alive
hmm dont know then mate sorry i don't think anyone else on here has had it done - maybe "tpw" whose car is being used by TDI for developments Ello. ;) |
#8 (permalink) | |
Commercial user
On the older EP3's we saw cars loosing power with the decat fitted on a standard ecu. If we fitted a mappable ecu and adjusted the fuelling/ignition we found good gains midrange and upto 10bhp at top end. There is no reason why the FN2 won't be the same, so would strongly recommend holding fire until the mappable ecu's are available. Decats used to work on the old Pugs, Saxo's, Novas etc as you could adjust mixture manually on some cars. You can't on these Honda's. Paul Last edited by tdi-north; 5th May 2008 at 20:21. |
It gets smaller as you said tp. Its going back im affraid. Plus theres an area of weld that is paper thin, bit of engine movement and heat expansion and i think it would start blowing in now time.
Hey ho. |
OK. Its the same as mine. The nuts that are welded on to hold the lambda sensors were also distorted on mine through too much heat when welding.
Graph now posted here: Civic Type R Owners • Login Last edited by tpw; 7th May 2008 at 14:45. |
| Performance Rolling Road Results | robbo51 | Engines and Transmission | 42 | 4th March 2008 18:09 |
| Decat out yet? | miniturbo | Type-R | 0 | 4th January 2008 23:16 |
| Survey Results | richierich | General Discussion | 9 | 14th July 2007 21:46 |
| JD Power Survey - the results are in!!! | Brodick | General Discussion | 72 | 1st June 2007 00:14 |
| Euroencap Results | tucker101uk | General Discussion | 2 | 29th November 2006 20:54 |
