This thread is about: Reverse Gear?, it's in Type-R at the Honda Civic forum Civinfo; Have notuce that when I select reverse to get off a quite steep drive my reverse gear does not seem to engage properly? It goes ...
Old 6th May 2008, 11:22   #1 (permalink)
jont122's Avatar
Reverse Gear?
It goes over and down but when I lift my foot off the clutch it is not in gear, causing me to reselect ,normally causing a bit of a crunching sound? as I hurrilly try to select the gear as I am in the middle of the road.
Never have this problem on the flat?
Is this normal?
Regards
jont122 is online now   Reply With Quote
Old 6th May 2008, 12:01   #2 (permalink)
gm1980's Avatar
I am experincing this kind of problem (which i do not consider it as problem) sometimes. My father had this problem with his civic 90s and when i putted the reverse on mine and did that characteristic noise he asked me "what's that noise". My aswer" "Its a CiviC".
Old 6th May 2008, 12:33   #3 (permalink)
914
914's Avatar
Your civic must be at a complete stand-still to be able to engage reverse without a problem.
As you mention you're on a hill, is there a possibility that your car is rolling slowly when you try to engage?
914 is offline   Reply With Quote
Old 6th May 2008, 13:59   #4 (permalink)
Type-R GT [R-11523]
Harlequin's Avatar
It could be the Synchromesh... try going into 3rd and then reverse (without letting the clutch out)...
If this stops the problem then you've got a dodgy sychro on your reverse gear - take it to the dealer...
-H
Harlequin is offline   Reply With Quote
Old 6th May 2008, 15:21   #5 (permalink)
Stephen B's Avatar
-H
doubt if reverse has a synchro, thought it was only the forward gears personally, but happy to be proven wrong
Stephen B is offline   Reply With Quote
Old 6th May 2008, 16:14   #6 (permalink)
alanwalne's Avatar
Civics have a speed sensor that will not allow the gearstick to move right of the 5/6 plane if there is any forward motion of the car.
Old 8th May 2008, 10:37   #7 (permalink)
lloeki's Avatar
IIRC that's only for more than 6kph.
rear does not have synchro (word from my favorite honda mechanic back when I had an issue with 2nd gear on my FK2) and never had on any car I had. plus the gears are straight ones (not helical and permanently meshed (engaged) like other gears which are (dis)engaged using a dog clutch linked to the shift lever).
so one has to be extra careful when engaging rear, else one might just wear out the gears to death.
lloeki is offline   Reply With Quote
Old 20th June 2008, 09:33   #8 (permalink)
did you ever work out what was causing this problem, im experiencing it too. car isnt moving and is on the flat but occasionaly it doesnt fully select reverse and when i lift off the clutch the gears grind not sure if there is an issue or its just me being careless, though never had this problem on my old cars...
mattj222 is offline   Reply With Quote
Old 20th June 2008, 13:05   #9 (permalink)
cnicolini's Avatar
I've had this problem too and took the car to the dealers. You have to be stopped and not moving before engaging gear. Sometimes the gear stick also sticks half way in gear and you have to force it out. The dealer told me that it was because the gearbox was new and still tight! Mine has now stuck twice in 9 months. They recoomended pushing the gear stick to the left hand side before engaging reverse as this will line up all the gears!
Similar Threads for: Reverse Gear?
Parking Reverse Parking Sensors for £50 ? Munro Electronics 6 15th May 2008 18:56
Options Does Civic EX come with reverse sensors Dan.82 Buying, Dealers and Servicing 14 29th February 2008 21:31
Transmission Reverse Gear cnicolini Engines and Transmission 14 5th December 2007 12:19
Speedo Speed Reading Driving in Reverse PIK20D Electronics 13 12th November 2007 19:05
Auto locks in reverse gear Copycat General Discussion 4 25th October 2006 19:28
