| This thread is about: Todays Stupid Question " ignition Key", it's in Type-R at the Honda Civic forum Civinfo; So...... here it is... How do you guys "turn the ignition key" ? Do you just twist it when inserted, or do you keep the ... | ||
How do you guys "turn the ignition key" ? Do you just twist it when inserted, or do you keep the presure on it before you twist.... Actually im having this conversation with a friend... I guess it does not matter how you do it, but it seems like it "turns" easier when the presure is on it... Without any preasure its harder to twist, like you have to twist a cylinder in....... Actually i never thought of this before, its just a thing which you do... |
I agree, thats "the worst part" of getting a new car
its like: maybe i break something if it is not turned correctly Last edited by Juff; 7th May 2008 at 13:05. |
I've always understood it could cause the blade of the key to snap if you exert too much pressure. Far better to slightly move the steering wheel to remove any pressure on the key and turn normally.
#9 (permalink) | |
This thread is actually pretty useful |
bit of spring force will stop barrel moving between positions when driving or going over rough surfaces and would be same on all cars with conventional keys methinks
#12 (permalink) |
I did this once with my old accord company car. Key snapped off in ignition- luckily was still usable, half was stuck in and all u needed to do was insert the other half and it worked fine!!- the car had done 180K so metal fatigue was probably the main factor.
| Phone pairing sony t68i ok, but voice says "no phone found"? | psykik | Electronics | 5 | 29th November 2007 14:00 |
| Tyre Choice Warning! "Fake" tyres being sold (including Goodyear F1) | Pottsy | Wheels, Tyres, Suspension and Brakes | 16 | 5th October 2007 11:43 |
| Quick Question: Rages & 18" 's | MoMatic | Type-R | 6 | 8th September 2007 14:25 |
| Satnav "No DVD Disc Installed. Please Check System." Error message | BobTheLoveGoat | Electronics | 2 | 30th March 2007 20:28 |
| Which spec To type "S" or to type "R" that is the question | Clouseau | Buying, Dealers and Servicing | 16 | 9th February 2007 14:48 |
