![]() Car: 2009 CTR, grey
Mechanical CEL Eliminator 02 Fix Sensor
Hi people!
I'm going to install a CPL Racing Manifold in my car. If I put this : Universal Mechanical CEL Eliminator 02 Fix Sensor Housing by:, does it ok to run with my stock ECU (while waiting FashPro)? |
![]() Join Date: 26th June 2008
It will work just fine. All that does is move the O2 sensor a little further out of the exhaust stream. Personally, I'm not a fan of that style defouler. I'm not sure how the layout on your car is, but on the FG2 the longer angled defouler works a lot better.
This is the one I have. It costs a bit more than the one you have listed, but I've been CEL free for 10,000 miles after installing it. Before the install, I was getting a CEL every 19 miles. Weapon*R Racing Development |
![]() Join Date: 2nd March 2009
I don`t want to spoil the party, but the CPL manifold has only one lambdasensor bung, because the manifold is specifically meant for use in combination with reflash. With this reflash you can delete the secondary O2 sensor.
You will need to weld an additional bung for the second O2 sensor somewehere in the collector to be able to run on the stock ecu as a temporary fix until flashpro can be installed. |
Similar Threads for: Mechanical CEL Eliminator 02 Fix Sensor
| Clean Underwear... In a mechanical sorta way!! | Nitehawk | Any non Civic chat here please! | 1 | 15th June 2009 14:05 |
| 2003 Civic - slight mechanical smell from engine bay | hughwatkins | Previous Civics | 2 | 12th May 2009 19:11 |
| Other MAF sensor | ddomy | Engines and Transmission | 1 | 15th September 2008 07:29 |
| Exhaust Second O2 Sensor Help | TRUE_AVALON | Engines and Transmission | 9 | 6th March 2008 16:17 |
| Oil Extralube ZX1 Friction Eliminator | Munro | Engines and Transmission | 8 | 18th December 2007 12:02 |
