This thread is about: Alpine Type R, it's in Type-R at the Honda Civic forum Civinfo; Hello!!! I've been busy this mornin installing a set of Alpine component speakers in my CTR . Fairly easy, took 3hrs to do both doors... ...
Old 6th May 2007, 14:05   #1 (permalink)
Harps's Avatar
Smile Alpine Type R
Hello!!!
I've been busy this mornin installing a set of Alpine component speakers in my CTR.
Purchased speakers from;
http://www.caraudiocentre.co.uk/prod...?product=22579
Speaker adaptors (from Halfords £12.99 same as these ones);
http://www.caraudiodirect.co.uk/vaux...ors-p-498.html
Speaker adaptor leads (no need to cut original wiring)
http://www.nexxia.co.uk/Speaker_adaptors/honda.htm PC2-818
Tweeter;
To remove open window and carfully prise off...
Once old tweeter is removed, cut away some plastic to make to hole big enough to fit the new tweeter unit. Once in it simply screws on with the plastic ring. The tweeter can be angled in any direction
Woofer and crossover;
To remove doorcard remove blanking plate behind the inside door handle and the two screws, and remove one screw from the armrest (under door handle) see prev threads for detailed pics big thanks to Pottsy
Doorcard simply clips off
Feed wire from tweeter through door frame to the crossover,
Use speaker adaptor to connect crossover to original honda speaker adaptor,
And use the wires supplied in the astra adaptor kit (break off
the astra adaptor "plastic bit") to connect the woofer to the crossover.
I used heavy duty velcro to stick the crossover unit inside the door...
I have ordered Dynamat Extreme speaker insulation to reduce rattle and interference...
http://caraudiosecurity.com/shop/pro...s_id/3051.html
Will install once delivered
Yes you do need to drill holes into the door to accomodate the astra adaptors
Finally screw eveything together and put insulating tape on all exposed connections,
Put the door back together and enjoy
(I was told by the guy from car audio centre to run in the speaker He said half volume max for the first 40 hrs else the speakers will get damaged)
Old 6th May 2007, 18:03   #2 (permalink)
sco77harris's Avatar
yer they do need running in lol, hopefully it will be worth it
Old 6th May 2007, 18:07   #3 (permalink)
Harps's Avatar
I heard them in the shop before I bought them. They sound excellent with good bass and vocal clarity, lets hope mine sound the same...
Old 6th May 2007, 18:11   #4 (permalink)
Looks like a good job there Harps, well done, I'm not nearly as adventurous/brave as you! Well done
Old 6th May 2007, 18:30   #5 (permalink)
Harps's Avatar
Thanks CZ, its easy once you've done the first one, as far as adventurous goes changing the speakers is as brave as i get
Old 6th May 2007, 19:12   #6 (permalink)
Type S Bournemouth's Avatar
im about to do my speakers shortly. Got the speakers sat here next to me still in there box!!!
Old 6th May 2007, 19:48   #7 (permalink)
same lol - when i habve the car back
Old 7th May 2007, 00:37   #8 (permalink)
Harps's Avatar
Go for it mate, doesn't take long and is fairly easy to do and you get that nice feeling of achievement once its done
Old 7th May 2007, 00:44   #9 (permalink)
well i have ordered the speaker rings today and the speaker wire adaptor. So im hoping to fit maybe next saturday if weather is fine.
Old 7th May 2007, 12:29   #10 (permalink)
DanKo's Avatar
Originally Posted by Harps View Post
Hello!!!
... snip ...
Nice one man, looks stunning!
If I buy all the kit would you be so generous and do mine?:P I only live around 30mins from you
If you want some money, then its cool
DanKo is offline   Reply With Quote
Old 7th May 2007, 13:50   #11 (permalink)
fanaticrom's Avatar
I'm hoping u decide to change the rear speakers as well
I want to change all 4 and a guide will sure come in hand
fanaticrom is offline   Reply With Quote
Old 7th May 2007, 15:42   #12 (permalink)
Harps's Avatar
Cheers mate! I tort u wanted the S3 I've got uni exams startin this week, aint got much free time but will be on uni hols in june, can help u out then if you want
The hardest bit is cuttin out the plastic from the tweeter housing, and drillin the holes in the door frame
Lol, the rear door cards are hard to remove, front ones are only a 2min job. I have got the bassworks subs in the rear doors, and the amp so don't think I will be changing them atm. I will be putting sound insulation around the front and rear speakers when I get some free time (june). Will defo post pics...cant be of anymore help atm
Old 11th May 2007, 00:17   #13 (permalink)
Griffyn's Avatar
Hey mate I had the 2005 Type-R Components in my old car and they were pretty decent speakers but always had they amped up, but when I sold the car took them all out and ran them off the Alpine headunit and they did sound good still. How do the 07 Type-R Speakers sound with the stock FN2 headunit?
Also don't know if your on CTRO (I am Vitz on there) but there is a CTR meet in Bham this wkend (weather permitting). If not is it possible to try and meet up some time (I am at Warwick Uni) as really want to hear the speakers as the standard ones are okay for OEM actually but really miss my hifi in my old car (All Alpine install with Type-R speakers). I was thinking but the Type-X speakers but Type-Rs are much cheaper and not going down the whole aftermarket hifi with this car (to save on weight).
Also good luck with your exams mate! Finished all my finals now Just labs and a cpl of 2nd year exams (module choices not re-takes).....then hopefully get a 2.1 and start my sweet job.
Griffyn is offline   Reply With Quote
Old 11th May 2007, 00:41   #14 (permalink)
Harps's Avatar
Originally Posted by Griffyn View Post
How do the 07 Type-R Speakers sound with the stock FN2 headunit?.
They sound quite good, I don't think they have fully bedded in tho but sound good. I've got the bassworks in the rear, not sure if the bassworks amp runs the front speakers
Im not on CTRO not in Bham on wkends anyway, not going to be able to make it After exams might be meetin up with DanKo to sort out installing the Type R's in his CTR, could have a bham meet in june
Yeah mate didn't want to fork out loads for the type X setup, but they do look really good. Im happy with my setup don't want aftermarket amps and subs in the boot (take up space and add weight)
Thank you mate , Im in first year got 8 exams (bio-chem) proper stressed out. Hope all goes well with uni and the new job, what course are you doing?
Old 11th May 2007, 00:59   #15 (permalink)
Griffyn's Avatar
The bassworks amp is only for the rear speakers. Heard it in the demo car I test drove and it was rubbish (no offence). TBH it didn't sound any better than the std hifi with the bass on +6.
CTRO = Civic Type R Owners and is another forum about the CTR. I like to use both forums since learn things on both, but CTRO has alot more CTR owners and is alot busier.
Yeah June sounds cool, but have the 2nd year module exams in mid June, but should find sometime. Would be cool to meet up with some fellow FN2 owners.
Managed to blag getting my hifi setup at the Alpine HQ in Coventry (about 2 miles if that from my uni) and they guy their said the Type-X speakers are more expensive but alot better than the Type-Rs, but tbh found the Type-Rs good.
Cant believe you have a CTR in your first year Good work!
I do something quite similar to you, I do Biomedical Chemisty but don't enjoy it at all. Yeah always get loads of exams with a course like ours, I have done 8 finals recently and then 2 other 'finals' in june.
Old 11th May 2007, 01:10   #16 (permalink)
Harps's Avatar
The bassworks amp is only for the rear speakers. Heard it in the demo car I test drove and it was rubbish (no offence). TBH it didn't sound any better than the std hifi with the bass on +6. .
Didn't pay for them part of the deal from the stealers
CTRO = Civic Type R Owners and is another forum about the CTR. I like to use both forums since learn things on both, but CTRO has alot more CTR owners and is alot busier..
Just registered Harps_CTR Cheers
Yeah June sounds cool, but have the 2nd year module exams in mid June, but should find sometime. Would be cool to meet up with some fellow FN2 owners..
My exams finish mid june so should be cool anytime after
Managed to blag getting my hifi setup at the Alpine HQ in Coventry (about 2 miles if that from my uni) and they guy their said the Type-X speakers are more expensive but alot better than the Type-Rs, but tbh found the Type-Rs good..
Cool yeah not heard the Type X but I like the sound of the Type R's
Cant believe you have a CTR in your first year Good work! .
LOL changed my course this year so technically 2nd year at uni
I do enjoy the course but its so bloody hard, so much to learn!!! Good luck with your finals, see you in june
Old 11th May 2007, 01:15   #17 (permalink)
Griffyn's Avatar
Haha fair enough if it was part of the deal.
Alot of people introduce themselves in the Newbies section. Also I am Vitz on there.
LOL at 2nd year comment Still a nice car at your age (not that I am much older )
Yeah June will be cool.
Old 11th May 2007, 11:30   #18 (permalink)
mr w1z's Avatar
I have the same speakers, I got my mate to fit them in for me I was in so much pain watching him drill and cut my baby especially as I only had my type r for 2 weeks but it was so worth it. I also fitted a pioneer amp/sub that fits under the center part of the back seats. My car Sounds great now especially compared to the crappy standard set up, plus my boot space isn’t taken up by a sub box like in all my other cars.
mr w1z is offline   Reply With Quote
Old 11th May 2007, 13:38   #19 (permalink)
Griffyn's Avatar
I have had my hifi stage until I get some mega powerful saloon when I am older so the weight doesn't matter. But for now don't want to add weight, so looks like I will only upgrade the front speakers tbh. The Type-Rs are decent speakers so will probably do this sometime. As for cutting up the car I don't mind as used to doing it with old car (pretty much stripped that thing when doing my alarm and hifis (had 2 different installs)).
Old 14th May 2007, 00:55   #20 (permalink)
Bravo's Avatar
Hi Harps,
Nice sound Man !
I can't imaging antyhing cooler, than crusin' in a Type R with beats at full vol.
Nice one.
Bravo is offline   Reply With Quote
