Go Back   Civinfo > 8th Generation Euro Honda Civic > Type-R
Old 10th May 2007, 19:12   #1 (permalink)
Gearbox, Enginestart .. any Problems?
i'm from Germany (sorry for my poor English) and i have ordered the new Civic Type-R to. I think i will get the Car allready next week To spent the time i'm reading all of information about this car. The first german FN2-Drivers writes about some Problems with the third Gear. It scratches and makes loud noises but doesn't gets in.
Second Problem that they have is to start the Engine. At some conditions to push the startbutton doesn't works.
Do you have this Problems? Do you have any infos from your Honda-Dealers how to fix them?
siam is offline   Reply With Quote
Old 10th May 2007, 20:44   #2 (permalink)
Harps's Avatar
Car: 2007 NHB CTR
no probs with the engine start, had problems with 3rd gear, slight hesitation when engaging 3rd gear when the engine was cold.
Ive done 1250 miles and its all sorted now. The gearbox is very smooth and slick gear change, Must have been part of the running in period
Old 10th May 2007, 22:48   #3 (permalink)
mw1978's Avatar
Car: 2007 CTR
Same problem is with 3 gear in civic SI. Change of MTF oil helps
http://www.8thcivic.com/forums/showthread.php?t=37769&highlight=gear+problem
mw1978 is offline   Reply With Quote
Old 13th May 2007, 06:57   #4 (permalink)
Tzn
It does happen sometimes that the car doesn't want to start when pushing the engine start button. Nothing happens really, you just have to push the button one more time and then it usually starts. Maybe not all cars are the same as mine...
Tzn is offline   Reply With Quote
Old 13th May 2007, 11:58   #5 (permalink)
THX1138's Avatar
Only happened to me once in 1 month. Just hit Start again and it will fire. Don't believe this is a problem. Had the same a couple of times in a Laguna.
3rd gear get's smoother and smoother. Haven't missed a shift for many days now. But it feels different then all the other gears for sure. Perhaps it's in my head. If I hadn't read about it here I probably wouldn't have known.
No problems with fuel-filler cap too
Old 4th May 2008, 21:50   #6 (permalink)
TYPE_R GT in NHB
Big_AL's Avatar
3rd gear is a known problem on CTR..and Honda now acknowledge the issue. My car goes in for new syncro fix on Tuesday. Car will be away for a couple of days..I'll let you now if it works. As for the starter. Interesting I thought it was only me. MAybe once in 100 starts the starter just whines. I just give it a 2nd go and its fine. I am not worried about this...Maybe I should be!!!
Big_AL is offline   Reply With Quote
Old 4th May 2008, 22:56   #7 (permalink)
R-2
found Nemo
R-2's Avatar
Car: 2008 TYPE R GT NHB
Had a problem with 3rd gear grinding but only very occasionally. Now having done just under 4000 miles it seems to have disappeared ( i hope )
Never had a problem starting. Push the red button and away we go every time
Old 5th May 2008, 07:34   #8 (permalink)
Wasser098's Avatar
Never had a problem with the start button. Engaging third can still be an issue from time to time (after 7,800 miles)
Wasser098 is offline   Reply With Quote
Old 5th May 2008, 07:46   #9 (permalink)
ReAVeR's Avatar
i had 3rd gear problem occasionaly but only the fisrt week, now its all fine.
(propably was my fault, i think my hand was faster than my foot or something )
as for the start button, never failed to start the engine it works 100%.
ReAVeR is offline   Reply With Quote
Similar Threads for: Gearbox, Enginestart .. any Problems?
Transmission Gearbox - Type R 3rd gear eddie1010 Bugs, faults and irritations 3 23rd October 2007 12:48
Transmission closer gearbox for civic '07 1.8 5d Roukounas Engines and Transmission 0 23rd September 2007 15:48
Any new CTR problems, i have.... mr w1z Type-R 10 2nd June 2007 02:14
Phone hft problems panasony Electronics 4 28th January 2007 03:24
Transmission Gearbox on i-CTDi Notchy Tydo Bugs, faults and irritations 10 5th October 2006 22:10
