| This thread is about: Speedo reading and 19 inch rages being out., it's in Type-R at the Honda Civic forum Civinfo; Ok i had some doubts about the speedo readings so took the time to use 2 different external sat nav's to get the readings of ... | ||
Ok i had some doubts about the speedo readings so took the time to use 2 different external sat nav's to get the readings of actual speeds.
TomTom one & Naviman Both showed that on average there is a 4-5 mph difference upwards between speedo and actual reading. Regardless of speed it stays the same - I was a bit surprised about this - expected it to be less at lower speeds and getting more the faster you got.. What did I test it between - constant 30 - 40 - 70 - 80 - 100 - 110. Has anyone had experience of this ? On my elise its about 7-8 mph but at the upper end of the speedo when your doing over 110 or so... Was a little surprised that it was so consistent further down the speed range with the CTR |
#2 (permalink) | |
Making the wheels bigger nearly always makes the speedo even more wrong than on standard wheels......in your case changing 18's-19's.
Yes, you can have the speedo re-calibrated, but as in your case, very few (read: No-one) ever has that done. Albeit only by one inch, you've still changed the 'Rolling Radius' of each wheel. |
Surely when upgrading your wheels you do a plus 1, 2 or 3 fitment to ensure that the rolling radius is practically the same as the standard wheels to avoid these problems and also more serious ones like rubbing suspension parts / wheel arch trim etc.
Mine is exactly the same, the speedo is not inaccurate via a percentage method but it seems to be between 5 and 7mph adrift across a wide spectrum.
Hello, this thread has got me thinking
Thanks |
0-60 ha !
those are quoted figures and to get an accurate reading youd really need a vmax - or data logger... Im sure someone will do that soon enough... |
Mine is about 4 miles per hour out from 30 up to 90 compared to my GPS. In traffic on the motorway I stayed parallel with a Citroen ** and that speedo was showing the same as my GPS. If Citroen can get the speedo accurate Honda ought to as well.
However I take the 4 mls an hour into account when going through cameras or along motorway restrictions so not a real problem. |
The 18" tyres are 225/40/18 and the 19" are 225/35/19. In theory, your speedo will read 0.5% slower with the 19" wheels on.
#12 (permalink) |
Kids use a lot of space
Interesting points here, but the result is not only related to the wheel size but the tyre fitted to it. Different makes have different dimensions so the figures vary make to make.
Standard figures are available for ETRTO (but not for free), however a comparison is available at: http://www.club80-90syncro.co.uk/Syncro_website/TechnicalPages/TRC%20calculator.htm |
#13 (permalink) | |
您看了
Funny thing is, my speedo is extremely accurate compared to stand alone GPS based sat nav systems I have tried. |
| Quick Question: Rages & 18" 's | MoMatic | Type-R | 6 | 8th September 2007 14:25 |
| CTR with Rages | MoMatic | Holdcroft Honda | 2 | 3rd September 2007 09:50 |
| R-Silver R-GT With Rages & More! | Mr JP | Gallery | 12 | 21st June 2007 00:05 |
| SOLD: Honda Civic 1.8 EX + 18-inch Alloys, 2006/56, 2600 miles | MattyMarsh | For sale and Wanted | 9 | 27th January 2007 14:38 |
| Speedo Speedo | Charles_Harding | Electronics | 9 | 24th August 2006 23:08 |
