| This thread is about: Air filter, it's in Type-R at the Honda Civic forum Civinfo; Hi All Does anybody know if the filter element in the new type R is the same as the old one? Also has anybody removed ... | ||
Air filter
Hi All
Does anybody know if the filter element in the new type R is the same as the old one? Also has anybody removed there resonator box or box`s yet? Cheers Duncan |
Air filter
I was looking to get a replacement element , I don't believe in induction kits. Regarding resonator box's I thought they were there just to kill induction noise, so what your saying is they help give you more low down torque?
Thanks |
#4 (permalink) | |
So at normal cars the resonator is mainly reducing induction noise... but as said mainly.. so there is some help in the low rpm filling also.. this ratio (noise/filling) is depending on the box how it looks like etc. etc. after a lot of hesitation, thinking I just kept everyting original on all of my cars. reasons: tha manufacturer tested it a lot, stock setup matches best to the ECU parameters, if you place a cool air intake (where the filter is in the engine bay) then the inducted air will be warmer than with the stock setup! (where the intake pipe is somwhere outside behind the front bumper) |
#5 (permalink) | |
I've also been asking around about the resonator box...Being from SA the guys who work on Honda's say that we could remove it and run a straight pipe into the airbox which will give better airflow and it should increase the sound a little bit...They said that the resonator helps with removal of water from the air, but mostly for countries with heavy rain and by us we hardly get heavy rain...They've done it alot on the older civics in SA and it makes quiet a noticable difference...
Does anyone have any pix of how the resonator looks inside the bumper??? |
| Oil Diesel oil filter? | Soichiro | Engines and Transmission | 2 | 21st August 2007 12:50 |
| K&N filter for FN2????????? | w.car | Type-R | 5 | 21st June 2007 14:04 |
| AEM Filter.. where to get? | tmartensdk | Type-R | 1 | 14th June 2007 21:31 |
| Other Air Filter | kamshaft | Engines and Transmission | 6 | 14th June 2007 12:39 |
| Induction K&N filter | trevorvogt | Engines and Transmission | 64 | 15th May 2007 16:30 |
