| This thread is about: Squeaks in the upper part of the dashboard, it's in Type-R at the Honda Civic forum Civinfo; I don't know if it's due to the f***g roads in this country, but I discovered recently that the upper part of the dashboard (exactly ... | ||
I don't know if it's due to the f***g roads in this country, but I discovered recently that the upper part of the dashboard (exactly above the rev counter ~ it's the plastc thing) makes an annoying squeak (like the one expanded polystyrene does) when going on bumpy roads.
If I hold it, it stops. I tried movind this platic upper part when stationary and it's doing the same noise (I did it just to be sure that I know what is the cause Anyone experienced this? Any solutions ? |
I had a similar sound that I thought was coming from the dashboard, but when I had a passenger in the car he had a good listen and by leaning forward decided the sound came from the roof area.
Took the car in and the mechanic came with me and also decided it was the roof area. Some removal of the foam somewhere in the area where the roof lining and windscreen join has drastically reduced the problem. So it must have been the sound reflecting off the windscreen and seeming to me as if it was in the dashboard area. Or it is just a different rattle/squeek fault! Terry. |
check out the 'Bugs, faults...' section - there are a few different threads on this sort of problem...
Click on the 'Prefix' link at the top of the list of threads, and it will sort them into groups. Squeaks are on page 6 |
My dashboard was squeaking severly for the first couple of thousand. The noise has gone now. The rubbing plastic must have worn enough. I'm on around 4k now.
| Suspension Front suspension squeaks / thuds | pikkumies | Bugs, faults and irritations | 162 | 27th July 2008 20:40 |
| Squeaks Squeaks and rattles and other minor problems | jalaman | Bugs, faults and irritations | 8 | 5th October 2007 22:19 |
| For the Veggies amongst us! Part 2 | Charles_Harding | Any non Civic chat here please! | 2 | 2nd June 2007 14:38 |
| REV display on upper dash | mgdoffshore | Was it you? | 7 | 31st March 2007 21:46 |
| Suspension Squeaks from the suspension | trollgutten | Bugs, faults and irritations | 0 | 14th September 2006 18:46 |
