This thread is about: FN2 clutch vibration, it's in Type-R at the Honda Civic forum Civinfo; I have noticed recently on my FN2 R-Type - that at the top of the pedal travel in any gear - a vibration playing through ...
Old 28th August 2007, 10:05   #1 (permalink)
I have noticed recently on my FN2 R-Type - that at the top of the pedal travel in any gear - a vibration playing through the pedal.
Noticeable when you are resting your foot on the pedal or just about to come on or off the pedal - its quite strong and im sure it hasnt been there before ...anyone with any ideas ?
Mo
MoOriginal is offline   Reply With Quote
Old 28th August 2007, 10:21   #2 (permalink)
Hmmm - I doubt it's much to worry about, especially if you can only feel it when you are on the pedal. But it's worth pointing out that resting your foot on the clutch pedal will very quickly wear out your thrust bearing, which will then cause vibrations (and stop your cruise control from working, if fitted).
Old 28th August 2007, 10:52   #3 (permalink)
Rocko's Avatar
Mo
Use the sodding foot rest!! That's what it's there for, and then what Pottsy said in bold, just to reiterate resting your foot on the clutch pedal will very quickly wear out your thrust bearing
Rocko is offline   Reply With Quote
Old 28th August 2007, 10:55   #4 (permalink)
Great Ive only been resting my foot on the pedal since Ive noticed the vibration to see how many times it happens
and for the other poster - do you have a vibration or something constructive to say ?? so dont comment then ....
Old 28th August 2007, 11:18   #5 (permalink)
Rocko's Avatar
No, I don't have vibration.
Nice attitude though.
Old 28th August 2007, 11:26   #6 (permalink)
Politely please, folks!
Mo, when you feel the vibration with your foot, does it vary with engine load, or engine speed, or vehicle speed (or a combination)?
Can you feel a strange vibration anywhere else, like the gearstick or steering wheel?
Old 28th August 2007, 12:15   #7 (permalink)
Erm not really the gearstick if i rest my fingers on the shaft doesnt feel abnormally too much vibration...
As for the the symptoms - defo its a combination - sometimes as you depress to change gear you can really feel it other times not so much.
Pulling away at low revs sometimes
sometimes when upshifting normal speed
the hard thing is trying to remember if i felt it before and ignored it
Old 28th August 2007, 12:45   #8 (permalink)
If it's when pulling away and upshifting, then it sounds like it's coming when the clutch is slipping. So that is most likely to be uneven wear on the friction material (should go after a bit) or something more serious like a broken or bent spring or plate. Does it grab?
If it's really abnormal, a trip to the dealer could be in order.
Old 28th August 2007, 13:10   #9 (permalink)
sorry what do you mean by grab ?
Old 28th August 2007, 13:12   #10 (permalink)
Judder - not take up smoothly.
Old 28th August 2007, 13:14   #11 (permalink)
Civic Mad!
I would definately take this back to the dealers but its probaly not urgent. It does sound like a slightly warped friction plate which disappears when it gets squeezed between the flywheel and pressure plate. It could also be a faulty spigot bearing/bush if the Civic has one. The outcome would probably be faster wear on your clutch but more anoyingly the feel through your foot which kinda spoils the driving experience
Good luck mate
m4rky is offline   Reply With Quote
Old 28th August 2007, 14:40   #12 (permalink)
thanks all
No judder as such thankfully...
Ill see what dealer makes of it - i know what their answer is going to be
Similar Threads for: FN2 clutch vibration
Transmission squeeky clutch?? Andrea Bugs, faults and irritations 45 13th January 2008 21:19
Transmission Worn Clutch Pedal Koen Bugs, faults and irritations 6 27th October 2007 17:23
Squeaks vibration noise from roof blind front deeny Bugs, faults and irritations 3 11th September 2007 12:24
Engine Vibration while idling. JB75 Bugs, faults and irritations 13 10th October 2006 21:32
Transmission Clutch Judder geoff Bugs, faults and irritations 10 13th September 2006 05:33
