This thread is about: Type R - Trick Rear Seats or Magic Rear Seats ???, it's in Type-R at the Honda Civic forum Civinfo; Does the CTR have Magic or Trick rear seats ? I found these pictures in an Auto Express test:...
Old 6th September 2007, 18:09   #1 (permalink)
Munro's Avatar
Question Type R - Trick Rear Seats or Magic Rear Seats ???
Old 6th September 2007, 19:00   #2 (permalink)
brawnr's Avatar
Good find on the picture.
I was told that the Type R NEARLY has the magic seats...the base of the seat folds up (as in the picture) but there is no way to secure it there. Apparently you have to secure it using the seat belts. The standard Civic has a catch of some sort to hold it in place.
Still waiting for my Type R, so I cannot give first hand confirmation of this!
brawnr is offline   Reply With Quote
Old 6th September 2007, 19:21   #3 (permalink)
philosoma's Avatar
What brawnr said is spot on, they go up but you need to use the seat belt to keep them there. The only magical thing about the front seats is they are comfy as and look the part
philosoma is offline   Reply With Quote
Old 7th September 2007, 00:14   #4 (permalink)
it's a 3 door thing - the type S has almost magic seats too
"you're gonna like this - not a lot!"
(apols to all the youngsters out there to whom that quote made no sense whatsoever )
Old 25th November 2007, 17:11   #5 (permalink)
Munro's Avatar
This is a daft question but I can't find the solution in the owners manual.
How do you lift the trick rear seats ???
When the seat is down there is a floor mounted hook over the seat leg where the green arrow points to in the picture. I cant find the button or lever that releases it.
Old 25th November 2007, 17:34   #6 (permalink)
druidh's Avatar
No "release" on the 5 door - just lift the seat base up.
druidh is offline   Reply With Quote
Old 25th November 2007, 17:34   #7 (permalink)
Vivid Blue Rocks!!!
Foggy69's Avatar
On the Type S, the hook is spring loaded. You just have to pull the hook far enough back to release the seat leg.
Just remember, when you put the seat back down, you have to manually pull the hook back again so that you can secure the seat leg.
It is a pointless and stupid bit of design. Why make the seats NEARLY magic.
Old 25th November 2007, 17:41   #8 (permalink)
ASH
ASH's Avatar
3D models are not designed to lift the seat base. That is why it's not mentioney in owners' manual, and a part of trim is missing at bottom of rear seat. That's what my dealer told me.
ASH is offline   Reply With Quote
Old 25th November 2007, 17:48   #9 (permalink)
Munro's Avatar
My hook moves about quarter of an inch when you push it by hand, but it does not move enough to release the seat leg. Do you have to force it to release it ?
Old 26th November 2007, 21:39   #10 (permalink)
Type R GT (R-8065)
SHADEMASTER's Avatar
It could be jammed,
My catch was a bit stiff to start with but after pushing the catch quite hard it now works okay.
SHADEMASTER is offline   Reply With Quote
Old 26th November 2007, 21:47   #11 (permalink)
Type R GT (R-8065)
My bottom seats in my Navara fold up the same was as the Civic but there is a catch to hold them up.
Using the seat belts in the R really don`t work (or it could just be me)
I found one of those elastic luggage straps the ones with the hook on either end worked best to hold the seats up.
Old 26th November 2007, 22:40   #12 (permalink)
pjr
pjr's Avatar
I'm guessing that the seatbelts in the R are the same as in the S - Once you have folded the seat bases up, pull the seatbelt out as far as it will go - as it then winds back in it will make a ratcheting/clicking sound and once the belt is tight to the seat base it will hold it in place.
The seatbelts ratchet in to secure non-isofix child seats.
Pictures here - Proof that the Type S has Magic Seats....
pjr is online now   Reply With Quote
Old 26th November 2007, 22:53   #13 (permalink)
Type R GT (R-8065)
I did wonder why Honda would go to all that bother of designing and build bottom seats that fold up but with no secure way of holding them there
Thanks Mate!
Old 27th November 2007, 04:51   #14 (permalink)
MrThanh's Avatar
same as mine. it doesn't seem like it moves back enough, but if you push it back as far as it will go and then lift the seat it will come up.
MrThanh is offline   Reply With Quote
Old 27th November 2007, 18:16   #15 (permalink)
jas72's Avatar
stupid question but why do you want
or need it to do this?
jas72 is offline   Reply With Quote
Old 28th November 2007, 06:52   #16 (permalink)
MrThanh's Avatar
extra load space for bulky/tall items?
Old 28th November 2007, 12:15   #17 (permalink)
jas72's Avatar
Like a small tree in a pot?
Old 28th November 2007, 13:00   #18 (permalink)
Type R GT (R-8065)
I have two Spaniels, folding up the bottom rear seats make it easy for the dogs to get in, and they can't damage the seats as they are sitting on the carpet
Old 28th November 2007, 17:45   #19 (permalink)
jas72's Avatar
The dog. Good idea.
Old 28th November 2007, 21:42   #20 (permalink)
Munro's Avatar
It looks like there are various uses from the posts below. For me it is because I am thinking of mounting a small sub woofer under the rear seat. Lifting the seats will give me better access for running cables / mounting the sub etc. I may also lift the seat for carrying something, as others have noted.
Thanks for the Good idea of using the seat belts to hold the seats up.
Similar Threads for: Type R - Trick Rear Seats or Magic Rear Seats ???
Proof that the Type S has Magic Seats.... pjr General Discussion 12 1st July 2008 22:54
FOR SALE - Civic Ex - Seats Front And Rear cabrio For sale and Wanted 4 15th March 2007 23:38
Seats (not so) magic rear seats JB75 Bugs, faults and irritations 11 2nd March 2007 19:16
Type R rear seats Frosty Type-R 2 30th January 2007 17:54
Magic S Seats Maldax General Discussion 1 26th August 2006 11:43
