Civinfo CPL Racing
Old 16th September 2012, 00:03   #21 (permalink)
dunleavy's Avatar
Thanks given: 1
Originally Posted by coste1l View Post
9mph?? 180° hairpins or something? I carry 40mph plus into 90° corners easily in mine and its just a noddy car
Sent from my GT-N7000 using Tapatalk 2
Sorry, I should have been more clear. I was referring to tight corners in the residential roads where I live - usually small streets. I just get the feeling I should be using 1st gear in some scenarios.
Is it possible to rev match into 1st gear to prevent the jerkiness?
And thanks everyone for your helpful answers!
dunleavy is offline   Reply With Quote
Old 16th September 2012, 00:13   #22 (permalink)
coste1l's Avatar
Thanks given: 1,110
Rule of thumb for me.... If the cars below 4k im in the wrong gear
coste1l is offline   Reply With Quote
Old 16th September 2012, 10:32   #23 (permalink)
Tom8126's Avatar
Car: 2007 NHB Type R GT
Thanks given: 460
Originally Posted by Jonathan W View Post
Your video shows 21 MPH (34 KPH) not 17 MPH (27 KPH) as you stated earlier and do you really drive in 6th gear at these speeds occasionally?
Your car's live economy rating goes up as you accelerate towards the end of the video meaning you should be in a lower gear at 21 MPH and not wasting fuel being in 6h gear
I would advise you to read the following thread:
Best gear for 30 Mph?
Just to clarify when the speedo is set in kph the economy works in reverse to mpg its lpk (liters per kilometer) so when you accelerate the number goes up.
Sent by me
Tom8126 is offline   Reply With Quote
Thanks to Tom8126 from:
Old 16th September 2012, 10:50   #24 (permalink)
Thanks given: 95
Interesting but surely 21 MPH in 6th gear is not good for the car as the engine may constantly be fighting to turn over at that speed?
You should try rev matching every time you downshift for the reasons explained in the link I posted earlier
Jonathan W is offline   Reply With Quote
Old 16th September 2012, 11:25   #25 (permalink)
Madcaddies's Avatar
Car: 2010 CTR CWE
Thanks given: 179
This
No way it is good for the engine to be in 6th gear at those low speeds. IMO you should by a different car. I can imagine you put more stress on the engine driving it like a granny
Madcaddies is offline   Reply With Quote
Old 16th September 2012, 11:48   #26 (permalink)
Henkepenk
DCShoesUSA's Avatar
Car: 2010 CTR GT FN2, DSB
Thanks given: 75
Just to clarify, my car runs well in 6th gear at those speeds without any stress at all if you just keep constant speed. I have more cars at home and I feel/hear if it would be stressful for the engine. I also see on the fuel meter wich speed/gear gives me the lowest result, which this does (:
And for driving like a granny, I'm more than happy to do this in towns with low speeds if it helps me saving fuel and not risking anyones life
DCShoesUSA is offline   Reply With Quote
Old 16th September 2012, 13:18   #27 (permalink)
dunleavy's Avatar
Thanks given: 1
I thought 1st gear was only really used to get the car moving? So it's ok to rev match down to 1st gear from a higher speed?
Old 16th September 2012, 13:20   #28 (permalink)
coste1l's Avatar
Thanks given: 1,110
Car should do about 40 in first so yeah it has its uses
Old 16th September 2012, 13:31   #29 (permalink)
Thanks given: 95
As coste1l said but 35 MPH (56 KPH) is the absolute highest the 1st gear can go before hitting the rev limiter in a standard FN2.
I find that 2nd gear is usable just above 9 MPH (the speed mentioned in your first post of this thread) without any engine labouring/struggling. If it helps, it's normal for the car to be jerky in 1st or 2nd gear when off the throttle due to its light flywheel which causes faster
engine braking engine braking
than other cars that may have a heavier flywheel
Last edited by Jonathan W; 16th September 2012 at 13:35. Reason: Added more information :)
Old 16th September 2012, 13:53   #30 (permalink)
dunleavy's Avatar
Thanks given: 1
I think I could reach VTEC more often if I used 1st gear...just wanted to make sure downshifting to 1st at higher speeds wasn't bad for the car in any way.
Old 16th September 2012, 14:08   #31 (permalink)
Thanks given: 95
It's not bad for the car as long as the car's current speed is below 35 MPH and you helping your car by rev matching. However, if the car's speed is over 35 MPH and you downshifted into 1st gear, you will over rev the engine beyond its rev limiter causing bad consequences depending how much it has over revved by.
The rev limiter cannot save you in this scenario since your car's front wheels are driving the engine over its rev limiter but if you are quick, you can press the clutch pedal and select the appropriate gear to prevent over revving the engine
As a general rule, I do not downshift to the previous gear if the car's current speed is less than 10 MPH from the previous gear's max speed. For example, let's say you are driving 50 MPH in 3rd gear (max speed: 77 MPH), you can downshift and rev match to 2rd gear (max speed: 55 MPH) but there's really no need as the VTEC engagement point is just 2 MPH away in 3rd gear (52 MPH). Just plant the throttle pedal down!
Last edited by Jonathan W; 16th September 2012 at 14:11. Reason: Grammatical mistakes :(
Thanks to Jonathan W from:
Similar Threads for: Noob driving questions
Noob The-dude Introduce yourself 13 26th May 2012 21:31
Noob uptoere Introduce yourself 12 10th September 2011 02:23
Suspension Springs..questions questions. cheeky Wheels, Tyres, Suspension and Brakes 0 16th March 2011 21:20
noob coste1l Introduce yourself 11 6th February 2010 08:52
Another noob britsbest Introduce yourself 20 30th October 2006 22:59
