![]() Car: 2009 CTR GT, Albaster Silver
Thanks given: 25
M-factory Final Drive
Hi was wondering if anyone has done this mod to their Fn2. Been thinking about this lately just wondering what the pros and cons are?
Been thinking about increasing the acceleration on my FN2 and herd this mod gives this car 15% increased torque making it good value for money instead of going down the n/a modding root which is highly expensive. My engine is completely standard so far just wanted to know what you guys think. Herd this will reduce your top speed but I don’t plan on going 146mph anytime soon but would like the extra torque. My car is a daily driver and planning on the occasional track day next year. What do you guys think to this mod? ![]() MFactory Competition Products - Forged Transmission Components |
![]() Car: 2006 1.8 Sport Ishift Milano
Thanks given: 127
Your rpm at all speeds will be higher. Worth baring in mind when you say you are daily driving.
#9 (permalink) | |
Commercial user
![]() Join Date: 3rd May 2008
Thanks given: 129
Anyone care to explain how a FD will actually increase a motors torque? A motor will only produce so much power/torque and that is at the flywheel. Adding something after that point won't suddently make any more power out of the engine. Changing the FD effectively shifts the power band from any given rev point further up the torque curve. Yeah thats right but you need to actually look at your curve in the first place and on an NA K20 motor your torque is actually dropping off. Certainly worth doing on a supercharged motor but downside is its also going to rev out quicker and in reality you could actually do with longer ratio FD to make full use of the power and get better mpg out of the setup. Different FD will actually mean the engine is running faster to maintain same mph as before so mpg will suffer. Basically your max possible speed is reduced. Don't get me wrong they are a great mod especially on a track car where your not going to be ever realistically using 6th so you can get the car to max out at 120 but on a roadcar that doesn't see a track, is a daily commuter probably doing a fair mileage and you think your going to get an easy power hike you really need to do a little more research. |
#10 (permalink) | |
Aye Aye....
![]() Car: 2009 CTR, Milano
Thanks given: 482
That was where I was going with not putting it onto a stock car, I'm happy to drop mpg on a car that will be getting a charger and only gets used for weekend fun, but daily, I wouldn't, it's hard to describe I suppose because torque isn't actually increased, but I suppose more available would be the best way to describe it, it's a good mod to do tho especially if changing out the clutch and doing diff since your in there anyway, worth considering. Or we could just get a turbo |
#11 (permalink) | |
Commercial user
Thanks given: 129
Go boosted and your find you actually need longer gears as your through 1-3 so quickly they are pointless. Cheaper and better option alround is to actually put 17" wheels on. Has same effect as shorter ratio's, plus a lot lighter which will also improve acceleration, more tire sidewall which generates better cornering grip and lastly tires are a lot cheaper! |
#12 (permalink) | |
Aye Aye....
Thanks given: 482
Do you guys not use a different FD on your TA FN2? |
Commercial user
Thanks given: 129
No. Still stock. The cars spinning out the corners as it is so last thing we want to do is make it worse. Have gone 17's though.
#14 (permalink) |
Thanks given: 127
You get more torque to the wheels by changing the final drive. That is how it works. You accelerate faster in 1st than 2nd because the ratio between the engine speed and wheel speed is greater for 1st gear. If you change the final drive you increase this ratio further and increase the force that can be applied.
Also switching from an 18" to 17" has virtually no effect on the torque from the wheels. 225/40 R18 tyre height = 90.0 mm. Alloy wheel diameter = 457.2 mm. Therefore, tyre diameter = (90.0 x 2) + 457.2 = 637.2 mm 225/45 R17 tyre height = 101.25 mm. Alloy wheel diameter = 431.8 mm. Therefore, tyre diameter = (101.25 x 2) + 431.8 = 634.3 mm 0.46% increase in torque to wheels by using 17" instead of 18". The weight advantage and moving the mass closer to the axle will benefit performance though. Last edited by delta0; 9th October 2012 at 11:27. |
#15 (permalink) |
![]() Car: 2008 FD2, Vivid Blue
Thanks given: 218
Good points - but don't forget, you can run a 40 profile tyre on 17 inch rims, which will significantly lower the effective final drive
#16 (permalink) | |
Thanks given: 127
The CTR comes with a 5.06 final drive I believe. Increasing to 5.46 would increase it by 7.9% Last edited by delta0; 9th October 2012 at 12:54. |
#17 (permalink) |
Cockup Specialist
Thanks given: 737
This is torque at the wheels vs speed for a typical FN2
The 6 curves are gears 1-6. Red is 5.5 diff Green is 5.1 diff The pdf shows the data and better pics if interested. ![]()
#18 (permalink) |
Cockup Specialist
Thanks given: 737
So in every gear the 5-5 is producing noticable more torque.
But the 5-1 can stay in gear longer ..so claws some of the advantage back. Now if you had a 5-5 diff and upped the rpm limit to give you the same gear speeds as a 5-1....then you would obliterate a standard 5-1 FN2 You'd need about 7.8% more rpm than standard to do this.....
Thank You to Relic from 3 Users:
#19 (permalink) |
![]() Join Date: 12th December 2010
Thanks given: 22
#20 (permalink) |
Aye Aye....
Thanks given: 482
Similar Threads for: M-factory Final Drive
| FN2 OEM LSD and final drive | Ciongas | Items for sale | 20 | 6th August 2012 00:24 |
| 5.062 final drive | allagios | Items wanted | 12 | 8th July 2012 19:24 |
| Transmission Oem FN2 final drive rate | ozzytik | Engines and Transmission | 2 | 20th November 2010 15:36 |
| 4.76 final drive. | allagios | Items wanted | 0 | 1st October 2010 13:09 |
| Final Drive | BRM | Injection Imports | 16 | 19th May 2010 14:18 |
