Civinfo CPL Racing
Old 19th October 2012, 20:18   #1 (permalink)
R555's Avatar
Car: 2007 CTR, Milano Red
Thanks given: 819
TODA Racing RRC
Does anyone know anything about TODA's RRC manifold?
R555 is offline   Reply With Quote
Old 19th October 2012, 20:20   #2 (permalink)
stoney's Avatar
Car: 2007 FN2 GT
Thanks given: 166
Its a ported out Mani like what Endyn offer.
Thought youd bought a Jackson Dave?
stoney is offline   Reply With Quote
Old 19th October 2012, 20:37   #3 (permalink)
pulpmelon_r's Avatar
Thanks given: 23
Have they reprofiled the plenum and runners or just the intake neck?
pulpmelon_r is offline   Reply With Quote
Old 19th October 2012, 21:08   #4 (permalink)
BRM
BRM's Avatar
Thanks given: 8
Dont think its any thing like the Endyns work at all. The TODA RRC its not even cut open, so the runners entrance can not be worked.
BRM is offline   Reply With Quote
Old 19th October 2012, 21:47   #5 (permalink)
R555's Avatar
Thanks given: 819
I have, but I was just interested to know what Toda did with the RRC as I thought you could port it out much due to the lack of material.
Old 19th October 2012, 23:27   #6 (permalink)
nunoctr's Avatar
Thanks given: 74
This is a real story.
Some time ago a friend of mine bought a rbc mani worked by one of the "best" usa tuners that port heads and mani for kseries. Imported from this tuner in the usa.
The car had x bhp after tuning.
But, some months after, he sold the car and the mani was out of the car and was lost. So he bought a rbc and ported the rbc himself for about 2 hours (never ported anything before) and said to the buyer "this a rbc ported by one of the best usa tuners"!
The mani was fitted to the car and we went to dyno... The car made 5hp more than the big ported rbc from the real usa tuner!!
After that all i can say is i don't believe on intake mani that comes from usa.
nunoctr is offline   Reply With Quote
Old 19th October 2012, 23:58   #7 (permalink)
R555's Avatar
Thanks given: 819
Thats terrible! So much for all the hype surrounding some of the US tuners.
I was reading a ported RBC still doesnt make as much as the RRC which is why I was thinking a ported RRC must be awesome. But it appears most of the tuners in the US only seem to port the RBC. I was also reading the Skunk2 is meant to be good for porting as there's more material on it and it can be worked more.
Old 20th October 2012, 00:00   #8 (permalink)
BRM
BRM's Avatar
Thanks given: 8
Fancy sharing Names Nuno?
Also, one cant put a Heavily ported Intake Mani on a set-up that doesnt mach, its the combination of parts that make the "best" power. Not just one or a randon number os parts put together.
Old 20th October 2012, 01:00   #9 (permalink)
nunoctr's Avatar
Thanks given: 74
The specs of the car was bc stage 2 cams, ssr header, 76mm skunk 2 exhaust, bi cai, big tb, 11.9 cr, stage 2 head and ported rbc... From the usa.
Old 20th October 2012, 01:02   #10 (permalink)
BRM
BRM's Avatar
Thanks given: 8
Thats not a bad set up, was that car in Portugal?
Who did the porting of the Head and RBC? Portflow?
Old 20th October 2012, 01:10   #11 (permalink)
nunoctr's Avatar
Thanks given: 74
Head was from blueprint racing the mani i dont want to say. It was in portugal yes.
Old 20th October 2012, 01:16   #12 (permalink)
BRM
BRM's Avatar
Thanks given: 8
Did know any EP3 with those specs.....
Personaly, im not a fan of Blueprint, not saying their work isnt good, but I would go there myself.
Old 20th October 2012, 01:22   #13 (permalink)
nunoctr's Avatar
Thanks given: 74
It wasn't a ep3. Swap k20.
Old 20th October 2012, 01:41   #14 (permalink)
BRM
BRM's Avatar
Thanks given: 8
Nice.
Was the RBC Plenum Cut or was it just "ported" from the runners exit side?
Old 20th October 2012, 02:05   #15 (permalink)
nunoctr's Avatar
Thanks given: 74
Nice.
Cut and welded
Old 20th October 2012, 02:59   #16 (permalink)
BRM
BRM's Avatar
Thanks given: 8
Cut and welded
Strange......
Back on Topic, I would like to know more about what exacly TODA do to the RRC. Maybe TDI-PLC will know..?
Old 20th October 2012, 08:19   #17 (permalink)
Lunar Tick's Avatar
Car: 2008 FD2, Vivid Blue
Thanks given: 222
I looked into this. They don't chop the top of the plenum off so the plenum end of the runners can't be worked on. Even if you were to do that, when you weld the plenum cap back on you'll then have untidy weld and rough surfaces on the inside of the plenum, which could be self defeating for airflow. I know they port out the TB entry to the manifold but I don't know whether they port out the end of the runners that bolt to the head. Even so, that might not be very effective unless you port match the inlet ports on the head...
Lunar Tick is offline   Reply With Quote
Old 20th October 2012, 10:56   #18 (permalink)
Commercial user
My trick Aluminium welding is try not to fully penetrate the joint, if you know what you are doing then the inside of the weld should be smooth and free of any weld. Not all that great for anything that requires structural rigidity but for an intake manifold, intercooler, pipework etc it's ok.
From what I know, the RRC isn't all that popular for porting in the states mainly due to costs and availability, but people that have ported them have seen better results over the RBC.
The skunk2 intake manifold does have more material therefore more potential but more flow doesn't always mean more power, as already mentioned in this thread everything has to be matched to work together.
Ideally you would have flow bench numbers with these ported manifolds, I know some companies do bench test them, (some are just going at them with a dremmel!) If you have a stock K20 with bolt on's then your intake manifold flow requirements would be different for that of say a K24 setup with cams ..
I think flow numbers are the key here.
Lou
Lou Connor is offline   Reply With Quote
Thank You to Lou Connor from 3 Users:
Old 20th October 2012, 11:05   #19 (permalink)
Lunar Tick's Avatar
Thanks given: 222
Good info Lou - thanks for this
Old 20th October 2012, 11:41   #20 (permalink)
BRM
BRM's Avatar
Thanks given: 8
If the work is done properly, that shound be a problem:
Similar Threads for: TODA Racing RRC
Toda Racing Flywheels mark@toda-europe Toda Racing 5 27th January 2013 23:08
toda racing a2 in and ex cams - toda racing valve springs ef9_b16a1 Items for sale 2 26th June 2011 18:13
Toda racing FN2 Stroker Kit mark@toda-europe Toda Racing 21 21st June 2011 18:28
Toda Racing K20 Connecting Rods mark@toda-europe Toda Racing 0 16th November 2010 18:45
Toda Racing Valve Springs mark@toda-europe Toda Racing 0 16th November 2010 18:43
