![]() Car: 2007 CTR, Milano Red
Thanks given: 819
17" wheels the same as changing final drive?
I was reading somewhere that changing to 17" wheels has the same effect as changing the final drive? Does anyone know if thats true? Also if you are going to change to 17's what offset and width would be best? |
![]() Car: 2007 FN2 GT
Thanks given: 160
Due the extra sidewall, switching to 17s isn't as big a jump as an FD change Dave.
If your doing it keep the wheel sizes just like the 18 options, offset/width etc just an inch smaller. |
Thanks given: 160
35 on a 225 would look meh, I have seen 17s on EP3s with 40 wall and it doesn't look right imo- on FN arches it's be even worse, 45 is a must but means the gain is marginal.
Weight wise though you can shave off a bomb with a good wheel/tyre combo |
Thanks given: 819
Oh well, guess I'll stick with the M Factory Final Drive then. Thought it might have been a win / win situation if it had a similar effect to the final drive as I could have got some 17" Pro Race 1.2's and saved weight and had better acceleration.
#12 (permalink) |
![]() Join Date: 2nd October 2007
Thanks given: 8
17"s on our FN2 bring only advantages!!!!!
Im running 235/40 up front on my Advan RZ and its still smaller than the OEM 225/40 18. The bigger wall, bring confort aswell as better cornering on slight bumpier roads. Its just alot better overall. Highly recomend. |
![]() Car: 2010 CTR CWE
Thanks given: 185
Sorry for jumping in but where in the UK do I buy 17" Gold Ultraleggera for my FN2 CW? Any good shops I should know about?
#15 (permalink) | |
Most Active Australian
![]() Car: 2010 Black Civic Si FK2
Thanks given: 67
A 225/45/17 tire has a circumference of 1992mm A 225/40/18 tire has a circumference of 2001mm A 225/35/19 tire has a circumference of 2011mm While the 18" tire has a circumference that is larger by 9mm which is small it is enough to throw out the speedo by 0.5km/h at 100km/h, and if you go for the 19" option your speedo will be thrown out by 0.9km/h or 1km/h But if you were to have a 225/45/18 tire equipped it's circumference would be 2072mm. This would make you travel 104km/h when your speedo says 100km/h(which is enough to get you fined these days) To counter this and have some leeway for other things speedos over read your speed by 4% or so. When i am going 100km/h on my cars speedo i am going 96km/h as seen on my SII GPS. The Official Site for the Best Online Tire Size Calculator |
#16 (permalink) |
Cockup Specialist
Thanks given: 740
You can fit...
225 35 r17 = 1851mm circumference (not much tyre choice though) 225 40 r18 = 2002mm circumference With a 5.1 you will end up with the equivalent of... 5.1 * 2002 / 1851 = 5.516 final drive But there is a weight saving too. Last edited by Relic; 22nd October 2012 at 12:27. |
#17 (permalink) | |
![]() Car: FN2 NHB Type R
Thanks given: 30
Sent from my iPhone. |
#18 (permalink) |
![]() Car: 09 Suzuki Swift Sport white
Thanks given: 1,117
Its how his brain works. Its the words between the formulas he struggles with
Sent from my GT-N7000 using Tapatalk 2 |
#20 (permalink) |
Cockup Specialist
Thanks given: 740
The diameter will be 2" less.
So you will have a 1" bigger arch to tyre gap. Coilies would be good.. avoid speed humps |
Similar Threads for: 17" wheels the same as changing final drive?
| FN2 OEM LSD and final drive | Ciongas | Items for sale | 20 | 6th August 2012 00:24 |
| 5.062 final drive | allagios | Items wanted | 12 | 8th July 2012 19:24 |
| Changing final drive worth it? | R555 | Type-R | 13 | 7th August 2011 10:29 |
| Changing Final drive ratio 5.1! | allagios | Type-R | 10 | 3rd October 2010 19:15 |
| Final Drive | BRM | Injection Imports | 16 | 19th May 2010 14:18 |
